Question about Goodman GMS90703BXA Heater
Furance won't lite
My furance wentout today now i,m trying to lite it i don't know the name of the furance but i do know that it don,'t have a pilot. it is equipped with an ignition device which auto light the burner. the model#gmt070-3 and the seriel#0207608633
  • frank1003 Apr 19, 2008
    i have the same problem the furnice wont light i have tried turning the switch to off then i wated 5 minutes then i turned it back to the on position it still wont light should i turn the thermostat to the lowest position and the turn it back on or what should i do it is a honeywell furnace
    Scholar:
    New Friend:
  • 70 Answers
The first thing i would do is turn thermostat down and turn power off wait for a few minutes then turn power back on and then thermostat back up. If it has a ignition module then there should be a blower motor. It should come on then a pressure switch that should click then the ignitor should glow or spark. there should be a round glass circle that you can look through to see the ignitor
Posted on Apr 26, 2008
Where is the reset button on a GMP100-4
Posted on May 03, 2008
Why does my furance not turn on when the pilot lite is lit?
Apparently it is not calling for heat. The thermostat needs to close. If it is wired correctly and the stat closes and it still does not start something is bad in the control section. You need to get a tech to help you. Randomly jumping wires is asking for a disaster.
Jan 11, 2015 | Heating & Cooling
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
Polit lite burning but furance wont ingite theromsat ok
flame sensor (ex. thermocouple) is not sensing pilot flame so it will not allow main gas valve to open
Nov 24, 2013 | Sterling Heating & Cooling
Gas furnace wont light
if pilot light is on, probably should be a knobs with settings for PL only, on, or off.
Nov 09, 2013 | Heating & Cooling
No heat gas log furance
if it has a pilot light, then it would not have an ignitor. also if it has a pilot light, it should have a knob that has settings for just the pilot light, just off, or on. Find that knob and check settings
Nov 09, 2013 | Amana ALG331RAW Gas Dryer
The pilot got wet and it won't lite up ???
There could be water in the pilot line or pilot is blocked and needs cleaning out along with the pilot line .
Dec 24, 2012 | Heating & Cooling
The pilot wont stay lite on the furance i already change the thermcoupler model # is srm-54815b montgomery ward
The flame must hit the tip of the thermocouple to get a good contact with the coopernickel bimetal.
Remove the new thermocouple and use a pencil eraser to clean out the hole. Get all the corrosion off there.
Oct 18, 2011 | Heating & Cooling
My fireplace pilot lite wont stay lite
There is a valve which you are bypassing when you press the pilot button. It is usually a sealed hydralic valve which holds the gas on as long as a flame is on the bulb. This expands the fluid and keeps the gas valve open. If the bulb moved and is not in the flame, or near enough, it will not stay on. Also since it sat for a year the internal workings of the valve could have "gummed" up. You need to replace the valve. You did not mention the name or model of the unit. Do a search with your units brand name followed by heater followed by parts. This should return dealers who can supply the part you need. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 25, 2010 | Desa International Unvented Gas Space...
THE FURANCE IS ABOUT 20 YEARS OLD I HAVE NEVER HAD ANY PROBLEMS WITH IT WENT TO TURN IT ON AND IT WOUNDNT COME ON CHECK POLIT LITE IT WAS OUT WENT TO LITE IT AND IT WOUNDNT LITE
Replace the thermocouple. It is the brass or copper tube that goes into the pilot light to detect the heat from the flame. If it is burned out, the gas valve will not open and the pilot will not light. They are universal and cost less than $10.
Oct 03, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Goodman GMS90703BXA Heater Logo
522 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
