Question about Tomtom One XL GPS Receiver
Tom tom one xl
Cannot turn on. i have pressed reset button and have tried to start it by holding down power button while pressing right side bottom corner of screen.still nothing happens
  • 5 more comments
  • boricua1953 Apr 12, 2008
    used it most of the day today and then turn it off for about 20 minutes when i tried to use it again it will not turn on
  • cdkmoose Apr 17, 2008
    TomTom had been working fine. Got in car today, plugged it in, green light goes on, but cannot get it to turn on. Has not been connected to a PC.
  • Anonymous Jun 18, 2008
    Tom tom was working fine then i turned it off and it would not comeback on
    when the power was plugged in the green light would show but nothing on the screen--i will try to open and see if the battery can come out and see if that restarts it
  • minky1234js Nov 22, 2008
    green light is on but screen does not come on
  • tbarricklow Dec 02, 2008
    Was working fine until I shut if down. When trying to turn back on only got a blank screen with green light on. Tried to reset several times to no avail.
  • keith_dear Dec 03, 2008
    Tom Tom is less than one month old. Was working fine until one day (no unusual circumstances) I tried to switch it on only to find the screen went white but did no more. Can occasionally, seemingly at random, get it to switch on, but the screen now flickers or has horizontal lines partially obscuring the picture top and bottom.
  • Anonymous Dec 04, 2008
    Worked perfectly til today then tried to turn on and blank screen. Green light lit and can here sounds of it coming on, but no screen !!
  • 502 Answers
If it doesn't turn on after a hard reset and disconnecting the battery you may have a logic board issue (also check if the DC-Jack is loose). In both cases there are <a rel='nofollow' href=http://www.portatronics.com>TomTom Repair</a>
Guides websites that show you how to replace / resolder components.
Posted on May 25, 2009
  • a7878 May 25, 2009
    If it doesn't turn on after a hard reset and disconnecting the battery you may have a logic board issue (also check if the DC-Jack is loose). In both cases there are TomTom Repair
Does the battery come off. If so take it off wait a few minute re -install and try again to restart.
Posted on Apr 04, 2008
How can i reset my symbol windows mobile mc7090
did you try this?
  1. Performing a factory reset using phone buttons
    1. Turn the power off.
    2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button. Release the VOLUME DOWN button when you see an icon on the screen.
    3. Then press the following hardware buttons in sequence: VOLUME UP > VOLUME DOWN > POWER > VOLUME DOWN.
Feb 12, 2015 | Symbol MC70 Handheld Mobile Computer (P/N...
Tip
TomTom GPS battery discharge when off
With the TomTom GPS units, if you use it infrequently, you may often find the unit has a dead battery when you go to use it.
This is because turning the Tom Tom off normally with the power button doesn't actually turn it off fully, but instead puts it in a standby mode.
Even though the screen is off and it appears to be shut down, it's still using some power to maintain configuration settings.
If you know you won't be using it for a long period of time, you can press the reset button on the bottom of the unit (this can be done while it's off), and it should put it in shutdown mode, where the battery will not be drained so rapidly. If you do this, you can confirm it's in the shutdown mode by tapping the on button. This normally will power up the Tom Tom, but in the shutdown mode, it will not do anything. To wake it up from the shutdown mode, press and hold the power button for a few seconds, at which point it should turn on and greet you with the Tom Tom drums. It takes quite a while to boot up from this mode, which is probably why they defaulted to the suspend mode instead of a true "OFF" state.
For some of the newer units, they've omitted the reset button, so the process is a little different. Instead of pressing the reset button, do the following:
with the unit on, press and hold the power button. The shutdown screen should appear, but continue holding down the power button for another 12 seconds after the screen turns off. Timing is a bit touchy, because if you hold it too long, it'll end up just rebooting, and then you'll have to try again.
If you're successful in the shutdown, you can test it by briefly pressing the power button. It shouldn't turn back on with just a short press. If it comes on with the tap on the power button, you'll have to try again.
This whole process is a bit of a hassle, and extends the turn on time greatly, so you'll want to plan ahead when doing this, and just shut off normally if you expect you'll be using it within a couple days. However, the long boot up is preferable to having a completely dead unit when you need it, especially if you're away from a power plug...
on Jun 30, 2010 | GPS
My son put a password on this tomtomxlone. he is7 and doesn't remember what numbers
PRESS AND HOLD DOWN THE POWER BUTTON FOR 15 SECONDS AND RELEASE THIS WILL FACTORY RESET YOUR TOM TOM FOR FREE.. TOMTOM CHARGE £55
Jun 01, 2011 | Tomtom One XL GPS Receiver
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
My Tom Tom one xl iq routes has frozen on the continue screen how can I fix it ?
What you need to do is to reset your unit. To reset your device, First check that the battery is properly charged. Allow the tom tom charge for about 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device by using a straightened paper clip or something similar to push the reset button for about 15 seconds.
Then you turn on your device by pressing and holding the power button for about 15 seconds. The picture of where the reset button is on your device is shown below.
Hope this information helped
Jan 05, 2011 | Tomtom ONE XL GPS
I accidently set my tom tom sat nav in foreign mode and I dont know how to get out of it. Please help
try to reset ..
1) Press and HOLD power button
2) While holding power button, press in RESET button
3) While still holding power button, release RESET button
4) Continue holding power button, you should see TomTom reboot
Oct 12, 2009 | Tomtom One XL GPS Receiver
MY TOM TOM 330 BOOTS UP BUT IT FREEZES AT THE CAR IMAGE WERE IT SAYS TOMTOM XL AT THE BOTTOM IT WON'T LOAD INTO THE ACTUAL GPS
Try to hard reset the unit press and hold the reset button for 10 seconds and then if still not work check if there is a latest firmware update and also make sure to properly charge the unit for 3 to 4 hours.
Jun 09, 2009 | Tomtom XL 330 Car GPS Receiver
Tomtom one XL
You dont specify "all the usual" things you have tried. Have you tried taking out the simcard if you have one and then pressing the reset button? Replace the sim and fire up the tom tom. Works for me.
May 11, 2008 | Tomtom One XL GPS Receiver
I can not turn on my 530 and it dos not show that the battery is being charged on the screen
Yes, there is a way to reset it. You can try the reset button under the faceplate, or a Master Reset. Keep in mind, a Master Reset WILL ERASE ALL OF YOUR FAVORITES. In order to do a Master Reset the unit must be off. Press and hold the bottom right of the screen, then press the on button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts. To use the reset button, you must remove the faceplate carefully (put your fingernail or another object in the indentation on the top of the faceplate, and pull it toward you). Then press the reset button on the right hand side of the unit.
Mar 02, 2008 | GPS
Tomtom One XL GPS Receiver Logo
605 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
