Pioneer Stero Receiver model SX-3700- Static noice when adjusting the volume control knob
  • Anonymous Mar 20, 2014
    no volume
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
    Genius:
  • 1,550 Answers
Tienes que abrir el aparato y echarle spray limpiador de potenciometros o echarle wd40 al boton de volumen .
Posted on Apr 04, 2008
SOURCE:
Sx212 how to repair volume knob- it crackles in use
Go to a good electrical component shop and buy a can of switch cleaner. Disassemble and spray the switch cleaner into the rear of the volume knob. There is always a small hole there somewhere. Spray it in and operate the switch with the power off. Wait 5 minutes and power it up.
Apr 27, 2018 | Audio Players & Recorders
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
I have a vintage pioneer stereo receiver model sx-727 wit the volume knob broken how can i fix it
That receiver is built in 1972 gona be very hard to find replacment.I suggest to go local repair shop and see if they have something that will fit as long the variable resistor (volume control part inside )is not broken
Aug 23, 2011 | Pioneer Audio Players & Recorders
Set the clock on KDC-138 car stero
hi if you click on this link it will bring up the instruction manual for your model. as well as the 238.
setting the clock is on page 10
hope i have helped, please dont forget to rate.
Jan 12, 2011 | Kenwood KDC-138 FM / AM Receiver
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Pioneer model sx-315 shuts off
if you are hearing noises from inside the amp,then something is burning up. Your sense of smell may be a guide here too. I suggest taking the amp to a tech to repair it unless you have had some experience with repairing amps
Jan 30, 2008 | Pioneer SX-315
719 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
