Question about Canon PowerShot EOS D60 Digital Camera
Problem with Canon EOS D60 Digital Camera
The contacts on my camera are not connecting with my lens giving err 01 message. shutter speed and apeture do not show when looking thru view finder however af points to read the focus
    An expert whose answer gotĀ voted for 100 times.
  • 155 Answers
You need to clean the gold contacts with a soft pencil eraser. Remove the lens, and clean the contacts on it. Then hold the camera so the lens opening is pointing down and clean the contacts on the camera. Ensure no debris gets into the camera body and none is left behind on the lens.
Put it all back together and you should be good to go.
Posted on Mar 24, 2009
    New Friend:
Thank you so much
Posted on Jun 12, 2013
  • samirmehmood Jun 12, 2013
    my camera is working know
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
Sometimes pictures are dark even in auto mode, err message is always coming, dark image in the view finder.
Hi dear pmorala
1) check
the lens if to drive the diaphragm actuating lever that opens.
2) also check the aperture lever on the camera body may be broken or bent.
3) look at the Shutter release the mirror and shoot the camera in a low speed (M mode) note if this works correctly or some of the leaves that make up the curtain is loose or out of place.
Everything seems fine ... OK command dial to select the full aperture, shoots the camera at you and see the diaphragm (set M mode and speed sh bellow 1 / 8). Full closed? = Aperture Mechanism defective.
Mar 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
Nov 15, 2010 | Nikon Cameras
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
Oct 31, 2010 | Nikon D40x Digital Camera
Camera won`t shoot
Have you tried taking off and then re-installing the lens?
Jun 29, 2010 | Canon EOS 40D Digital SLR Camera Digital...
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
Canon PowerShot EOS D60 Digital Camera Logo
196 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
