Question about Cameras
I just bought an Audio Technica brand microphone for the Panasonic DVC20P. The mic works but the sound only comes out of the left ear. The camera's built in mic does not have this problem.
  • 2,334 Answers
Make sure that you have a stereo plug on the microphone to be able to get both channels.
Posted on Apr 04, 2008
  • Jaime Hernandez Apr 04, 2008
    If you have one like the one on the picture, I would suggest to check a replacement.
  • 3,037 Answers
The microphone sounds defective, I would just return it and get a new one since you just bought it. If the second one has the same problem let me know but if a different mic works with both speakers then the new mic should be the problem
Please keep me updated, thank you
My windows laptop does not detect the mic when i plug it in. it used to, and i know that the mic works
If using windows 7 go to sounds then properties then go to microphone than make sure enable after that test levels
Oct 14, 2013 | Audio Technica Audio-Technica ATR-20...
Connection
if it plugs into the line in or mic in using the 3.5 mm plug then no, the mic won't need a driver. Your playback and recording devices on your computer DO need drivers. Sounds like a computer config issue to me. Could be a few different things
Hi i am using the audio technica at2035 condensor mic and the m audio mobile pre 2nd gen. audio interface. yesterday the mic was working fine with no problems but today for some reason i have to really...
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Nov 29, 2010 | Audio Technica AT2035 Professional...
What drivers can i download to make my at2020 usb work with windows vista
i hav just bought a at2020 mic and i tried recording bought it's not workin for my dell inspiron i forgot the model anyway it's running on windows 7 so please help me out am screwed with this ****
Mar 13, 2010 | Audio Technica Audio-Technica AT2020 -...
My mic keeps getting this popping noise wen i record, i have a pop filter an it's not a wind noise it's a crackling sound
Is it a condenser mic? Either your mic is bad or you need to add a compresser to your signal path...
Feb 09, 2010 | Audio Technica Audio-Technica AT2020...
My church bought 4 audio technica free way 700 series microphones about a year ago and from the beginning we had problems with them. Now only one of them is working! There is no warranty and we really need...
Audio Technica is generally a good brand name in microphones, but sometimes if you talk to musicians they tend to favor names they are familiar with like Sure. In the church, school, venue world, audio technica is respected. I work audio in three separate venues and we have no trouble with our audio technica microphones.
Have you adjusted the channels--and have you tried to do so manually? Have plugged the working one into the same inputs the nonworking ones were plugged into? I know it sounds like a simple thing to ask, but sometimes the connections to the sound board are the issue. If you have the more advanced receiver for the freeway 700, there are other adjustments designed to allow you to adjust between guitar and voice. If it is preset to guitar it will not sound good for voice. You may have to change that. I am assuming you put in new batteries, but ifyou have not, you may want to try that as wireless mics use up batteries quickly.
Those are a few possibilities. If it is the actual unit, then you can look inside and see if something is loose, but as far as repair, that gets into a whole issue. Hopefully something above helps solve the problem
Sep 06, 2009 | Dual Audio-Technica ATM250DE Microphone
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
Low Freq Pulsing on Audio Technica AT4040 Microphone
That is a condenser mic and I bet the others you are trying are dynamic. Does your unit supply phantom power? It should. Or look for a power injector as a separate box.
Mar 03, 2018 | Audio Technica Audio-Technica AT4040...
Want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Aug 05, 2007 | Audio Technica Audio-Technica DR2600...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
