Question about Philips 9P5034C 50" Rear Projection Television
Cloudy Picture We have a 2000 Phillips Magnavox the picture looks quite cloudy and it hurts your eyes to look at it for too long. Can you tell me what might be wrong with it and how I can get it fixed? I don't know much about televisions, but like this one and would like to know if it's worth fixing.
  • sha41497 Jan 23, 2009
    I just recently bought this same TV used and I have the same problem. The picture looks like there is a white haze over it. I have attempted to adjust all of the picture settings and nothing makes the picture look better.
  • Anonymous Apr 02, 2009
    color is cludy and blury
  • Philips Master
  • 8,617 Answers
Can you psot a pic of what the picture looks like. I should be able to diagnose it if I can see the image and what its doing.
Posted on Apr 04, 2008
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Jan 03, 2014 | LG Televison & Video
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 22, 2009 | Televison & Video
Cloudy picture
NO, IF YOU SPILL ANY OF THE FLUID ON THE BOARDS THEY ARE RUINED AND ALSO IF YOU DO IT INCORRECTLY THEN YOU WILL HAVE TO RECONVERGE THE ENTIRE SET AND THIS TAKES A LOT OF TIME AND SKILL.
Sep 14, 2009 | Televison & Video
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips projection television 106
Change the coolant in the CRts and the color and clarity will be restored. This is a common problem with phillips CRTs the coolant gets cloudy and needs to be replaced.
May 26, 2008 | Televison & Video
Philips 9P5034C 50" Rear Projection Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
