Question about Brother HL-2040 Laser Printer
Won't Print But Ready Light On Fan nonstop
This is on multiple xp pro and xp home computers.
I told my friend how to reset toner process over the phone. I think he might have done it wrong. I've tried the reset all process also.
-What happens is the printer turns on and the ready light flashes a bit then stays on forever instead of flashes while the fan doesnt turn off anymore.
-not able to print
-computer detects if usb is unplugged or plugged in but cannot print.
- when toner access slot is open and then turned on the paper light flashes.
- if go button is held while turned on then let go no lights display.
  • tutik Jun 17, 2008
    the same happened to my printer after resetting the toner using the button procedures. is there a maintenance mode or something for this printer?
    New Friend:
  • 159 Answers
F the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Apr 08, 2008
My HL2040 laser printer will print "Print Settings" page but otherwise will not print at all.
Set this printer as the default printer or if there are multiple printers connected or installed specify the printer issue print command
Jun 06, 2015 | Brother HL-2040 Laser Printer
HP LaserJet Pro CM1415fnw stuck in calibration mode, won't print
there's a few reasons why your printer is doing this - I would recommend the following action:
1 disconnect the printer from your PC ( USB/Net)
2 power off the printer
3 open the top/ front and pull out the process section( where you put your toners)
4 individually remove and then reseat these toner cartridges
close the covers back up and power on ( still disconnected from the PC)
5 allow the printer to come to ready ( if it wont come to ready there may be a problem with one or more of the toner cartridges)
6 print an internal testpage ( press menu , select information, select configuration, select print)
7 whent his prints you know your printer is going to be ok, On your PC-clear ALL the print queue- reconnect to printer and test!
Mar 21, 2014 | HP LaserJet Office Equipment & Supplies
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
My Lexmark E250DN : 02 led on the right hand is ON, the system restart and can not print. Any suggestion for help???
You can press and release Continue button to clear the light sequence and continue processing the print job. Turn the printer off and remove the toner cartridge, and shake it to extend the life. If toner light is on, replace the toner cartridge.
For further assistance, please call Lexmark Technical Support.
Jan 11, 2011 | Lexmark E250dn Laser Printer
Hi I have just reconnected my Konica Minolta Page Pro 1400 and installed the new cartridge - when I switch it on I can hear it start running and then it stops and the fan keeps going but the error light is...
In the user guide, a blinking error and ready light may indicate a communication failure and to make sure the printer cable is seated properly. Otherwise a blinking error light only indicates a media jam or no toner cartridge installed. For the media issue, make sure no paper is caught anywhere inside the printer. If the toner is the problem, try another cartridge. One of those should solve your problem.
Dec 01, 2008 | Konica Minolta PagePro 1400 Laser Printer
Says ready, error light blinking, vertical non-print line
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Aug 13, 2008 | Konica Minolta magicolor 2400 Laser...
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
290 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
