Question about Panasonic KX-TG2313 Cordless Phone
Turn off ringer?
We would like to turn off the ring tone completely so we are not disturbed by phone calls late at night. No longer have instructions. Can you please provide me with instruction on how to do this?
On the base, to turn the ringer off, press and hold Volume Down [V] until the unit beeps 2 times. On the handset you can use the menu to turn off ring. This way, you can choose to receive and take the urgent calls.
Posted on Nov 24, 2008
    Problem Solver:
  • 19 Answers
You can make use of DND(Do Not Disturb) feature. Turn it on at night and turn it off during day. For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you can use it to turn on/off DND.
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 1 to enable Do Not Disturb. ( Press 2 to disable)
3. Once you hear the confirmation that Do Not Disturb has been enabled, you may hang up the phone handset.
Hope this helps!
Posted on Nov 13, 2008
How do I turn the volume of the ringer off on Nortel T7316E. I don't want it on 'do not disturb' as I need to take calls/allow them to go to voicemail, but don't want to hear the ring.
Two different options,... Call the extension, and while it is ringing, press the volume down bar until you can no longer hear it ringing. You can also try this... Leaving the handset down, do Feature * 80, adjust the loudness for ringer volume by pressing the volume bar.
Oct 21, 2016 | Lands Phones
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
The ringer of my phone is off. How do I turn it on?
flip open your phone -then increase volume with side ^ button...this toggles ringer on/off
no need to go into phone settings...
Aug 05, 2010 | Cell Phones
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
GE cordless dect 6.0-do not disturb
According to the instructions, you only need to press the "do not disturb" button again. The button is on the base (not the phone).
Mar 04, 2008 | Uniden Cordless Phone
No ringing tone or incoming call sounds.
The primary phone sets the ring for all phones. If it is off, nothing will ring. Once it is on you may set the volume of the rings on all sets individually. If you have the manual, look under Ringer Off on the main set. Hope this helps, let me know
Feb 18, 2008 | Siemens optiset E Corded Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Panasonic KX-TG2313 Cordless Phone Logo
283 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
