Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer leaking Can't figure out how to open it up so I can look for the leak. Can you help? It is called the Kenmore Elite Calypso Wash Motion Thanks
On the front of the machine there is a oval shaped medallion that says 'whirlpool' - pop that out and remove the screw. Next, on the sides about two inches back from the front there are two posts that help hold the top on - use a wide screw driver or putty knife to pry the top up. Once the post disengage it's a easy sailing, sort of.
Posted on Apr 15, 2008
Everythings goes okay until the last cycles and or minutes then it starts to leeks then it just recycles I had codes like L D, O b and the final one was d t. Whats going on with this machine
Posted on Mar 10, 2011
I GET THE FL DISPLY ON MY KENMORE ELITE CALYPSO WASH MOTION. HOW CAN I REMOVE THAT SO IT CAN START WORKING AGAIN
unplug your washer for 5 minutes and try it...these washers are known to have pump issues..if its older one..the pump can be replaced...if its newer..the motor/ pump has to be bought and replaced...
Jan 22, 2011 | Kenmore Washing Machines
How to Open up a Kenmore Elite Calypso Wash Motion Washer: I opened up the lid but how do I release the the snaps that hold the inside machine to the outside...?? I have a lot of "sludge"...
Just checked the service manual on this model. To open top, first UNPLUG the cord, then gently pry off the emblem from the front trim. Behind it is a T-20 torx screw, remove it and then you can pull the entire top toward you, the front, about half an inch or so to clear the latch and lift the entire top. It's hinged at the back. Ensure you have enough room behind the machine for the console to clear and prop the lid up. If machine is still under warranty, I wouldn't recommend self service, if not, have at it, all you can do is save yourself some money!
Hope this helps
kcomp1863
Jan 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
2000 Calypso Kenmore Elite (wash motion) it has a slight leak, we have no clue where it is coming from, my husband has it laying on down to see, all the hoses look good, we cant tell if its the clamps,...
dont lay it down,,,,stand it up and lean it back than fill with water,,be careful use a prop..another way is to slide news paper under unit,,than we can tell what area its leaking from..unit make only leak in drain,,so we have to test unit in drain to ckeck that system,,onthejob
Jan 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
Apr 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
