Hi i have a 1070-b gateway 1 port etherney modem/router adsl2/2 and my problem is i cant configure it to my pc here in the uk i have windows xp
  • 1 more comment
  • harry134 Apr 04, 2008
    i need a install disk and manual were do i get these
  • harry134 Apr 05, 2008
    that seems to be for the usb version i need info and drivers for a eternet version thanks
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Did it come with an install disk and a manual? If so do you mean you've tried and have just had problems.....Or do you need these things..If you tried, explain the pronlem a little more if you would please.
  • 667 Answers
Here is a link for the driver and manul. Under operating systems choose the two on the left for Windows for driver and instuctions. On the right under the documentation section there is one manual that coners the 1000 series. That's the one you want. If this fixes your problem please rate as fixed. Thanks.
http://www.2wire.com/?p=266
Posted on Apr 04, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Apr 04, 2008
    On the right there's also an installation guide.
Compaq presario sr2050nx windows xp media center edition 2005. cant reconnect to internet, says network cable unplugged. but it isnt and the device manager says its working properly and that there were no...
It *IS* unplugged, either at the end that goes into your network-port, or at the other end, where it goes into the cable-modem or router.
Or, the cable-modem or router at the other end is OFF.
Try a different cable.
Apr 02, 2011 | HP Compaq Presario SR2050NX PC Desktop
I have a belkin router i am having trouble connecting it. i dont know where to connect the ethernet cable. Does it go the computer or the modem?
the ethernet cable should be connected to the ethernet port of the router to the ethernet/network port of the computer. you will also need to connect a cable through the router and the modem, then a phone cable from the modem to the phone line.
Aug 31, 2010 | Computers & Internet
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
http://portforward.com/
May 10, 2009 | Computers & Internet
I have just purchased a dlink dir 635 router and am trying to set it up on my Bigpond cable broadband internet. previously I had only a Motorola SBG900 gateway between cable and pc. I now have the new...
The motorola sbg900 is acting as a router itself. I'm assuming this is what you've got? http://promo.bigpond.com/homenetwork/html_new.php
So first, go into your d-link router settings and make sure the THIRD number in the IP address is the same as your modem's ip address. This third number is the "subnet", and it must be teh same for both router and modem.
e.g. if your motorola users ip 192.168.2.1, make sure your d-link is set to 192.168.2.2. Make sure the fourth number is different, but the 1st 2nd and 3rd numbers are the same.
You can figure out what your motorola's ip is by connecting it to your computer, make sure your interent is working, and then run "ipconfig" from a command prompt window. Look for the "Default Gateway" IP. That's your motorola's ip address.
Once the IP addresses match, go into your router's settings and disable the "DHCP server".
Next, plug a network cable to go from one of the LAN ports on your motorola to one of the LAN ports on your d-link. Note that it is LAN port to LAN port. The "internet/wan" port on the d-link is never used for anything.
At this point your d-link will be operating like a "Switch", it knows it is just an extension of your existing network and it won't collide and cause you problems like it was before.
Dec 06, 2008 | Computers & Internet
How do I disable wireless capabilities on my modem
Hi louanne,
If your modem/router was provided by your internet service provider (ISP) you may check the configuration with them. Your modem/router wireless capabilities can be disabled by accessing the device. You should be able to get the IP address, default gateway and the username and the administrator password. Your computer should be hardwire to the modem to get the ip address or the default gateway.
regards,
jeff
Oct 10, 2008 | Computers & Internet
I have a ZyXEL P-660HW-TI ADSL wireless router used as the gateway and wireless AP (also the wired ports are used for LAN). It has no VoIP ports. I do have a 2nd ADSL router (not used: no wireless, 1 LAN...
No because the VOIP need to be loged in first. if you have the voip first then the wireless router and you turned off the router dchp section part of the wireless modem then perhaps it will work, plus you need a voip account.
Jul 03, 2008 | Computers & Internet
Vista PC connecting to DSL-504T modem/router
first make sure that model router you have supports vista. i can help you more if i had alittle more info on your router.
Jun 01, 2008 | Compaq Presario 5000 PC Desktop
I cannot set up my Linksys wireless router model number:WRT54GS to work properly. I have a desktop computer with Windows XP operating sysyem. I have three other laptop computers with wireless components
The easiest would be to connect your desktop straight to your modem and verify that you can connect to the Internet. Do not use the LinkSys WRT54GS yet. Pop in the CD that came with the WiFi Router and run the setup wizard. Follow exactly on screen instructions. Verify that your desktop's networking is set to auto obtain IP address.
Alternately, you can try:
1. connect your desktop with a straight through LAN cable to Ethernet Port #1 of the WRT54GS;
2. set your desktop to use IP-192.168.1.10, Subnet Mask-255.255.255.0, Default Gateway-192.168.1.1;
3. open a browser and goto 192.168.1.1. use the LinkSys supplied username and password;
4. verify/configure/set the LinkSys to your preference;
5. for the time being do not use any security keyphrase, WEP WPA or MAC filter;
6. verify that your laptops could see the router's SSID;
7. verify that all laptops are set to auto obtain IP addresses;
If for some reason neither method will not work, pls post back with your modem's make & model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 07, 2008 | Computers & Internet
How do i reprogram a 2wire 2071-A
Do you have your instructions? I can tell you but it would be easier for you if you can just look at the guide and take your time. You can do a reset and then reprogram. If that's all you want to know I can do that. Would you want me to get you athe manual or tell you specifically how to do something?
May 03, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
