Question about Frigidaire FEF336BC Electric Kitchen Range
Oven won't heat up to set temperature
I have a beaumark range that's about 4 years old. The oven won't heat to the set temperature. It doesn't get above 320. The broiler works just fine.
    Novelist:
  • 184 Answers
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Posted on Apr 04, 2008
My Kenmore Gas Range 790 makes a puffing sound every time the oven cycles on. Sometimes it is quite loud. In addition when I set the temperature the preheated beep sounds well before the temperature
It sounds like your oven igniiter is the problem. the part that glows in the oven. they get old after a few years and you can get a miner explosion when the burner lights. Replacing the igniter should fix this.
Nov 06, 2014 | Kitchen Ranges
Oven not heating up too well :-(
please check the following:
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
Jan 18, 2010 | Kitchen Ranges
Oven Doesn't Even turn on
The oven thermostat controls the oven temp. It is not working and you need a new one.
Jul 01, 2009 | Roper FGP305 Gas Kitchen Range
Amana first addition oven (approx 10 years old) will not heat
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Dec 23, 2008 | Amana AGDS902 Gas Kitchen Range
Beaumark oven self cleaning
I lost my manual for the appliance, i was wondering if anyone knows how to get one? Thanks in advance
Jan 07, 2008 | Whirlpool RF378 Electric Kitchen Range
GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
305 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
