Toshiba TV/VHS/DVD I was watching VHS tapes and now I can not get TV picture. I must have pushed a wrong button on remote.
  • 16 more comments
  • tomijean2 Apr 04, 2008
    I tried that and it did not work. I have cable so of course I have two remotes and I pressed TV/VCR on Toshiba remote and cable on cable remote
    I was watching VHS tapes on my Toshiba MW30G71 Combination Flat Color TV and Video Cassette recorder / DVD video player. I must have pressed a wrong button or series of buttons as now I can not get TV. I have cable service and have a remote for both and have pressed TV/VCR on TV remote and TV and Cable on cable remote. Thank you.
    It is a combination and the button is labeled TV/VCR and it is on channel 3
    I was watch videos and when I would stop, eject tapes it would go back to TV. I was also stoppng, rewinding and fast forwarding. Then all of a sudden it did not go back to TV, so I must have pressed a wrong button or series of buttons. There is no sound and tons of snow.
    I unplugged the TV combo and the cable box and rebooted. Still no sound and tons of snow.
    Thank you, I am just stumped. I just inserted a video and it played beautifully, picture and sound.
    It is a combo TV/VCR/DVD
    No TV at all, but VCR is working
    I was watching videos and when I would stop, eject tapes it would go back to TV. I was also stoppng, rewinding and fast forwarding. Then all of a sudden it did not go back to TV, so I must have pressed a wrong button or series of buttons. There is no sound and tons of snow.
    The VCR and DVD are built into the TV.
    Channel 3
    It is set on cable
    No, just the VCR, not the TV. TV is still tons of snow and no sound.
    The only choices on TV setup menu are either TV or Cable and I am on Cox Cable so I chose cable.
    I put in a DVD and it worked beautifully.
    VCR and DVD are working no TV
    The VCR and DVD were never a problem, The problem is No TV. The VCR and DVD are still working and still no TV. Please can someone help?
    no it is not working
    Brigadier General:
  • 6,966 Answers
If I may add to the other suggestions...
Depending on how your cable box is connected to the Toshiba MW30G71 combo. The simple connection maybe:
1. Cable box through RF OUT connected to RF IN of your TV combo. Toshiba set to Ch 3. or
2. Cable box through Audio/Video OUT connected to Audio/Video IN of your TV combo. Toshiba set to Aux or Video IN.
Though the cable box may be connected in any of the other INPUT selections such as HDMI, S-video, Component Video and would require that you cycle through the different input selection/choices.
If problem persist, you may need to do the set-up procedures again on the cable box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 04, 2008
  • 3 more comments
  • Louie  Role
    Louie Role Apr 04, 2008
    Of course to verify which of the many inputs your Toshiba is using to be connected to the cable box, you need to visual check the connection points/terminals. Pls determine what jacks are used in the cable box and into what jacks they go into in your Toshiba. Thereafter using your remote select that particular INPUT.
  • Louie  Role
    Hi again,
    You rated my proposed solution as "FixYa", may I assume that your issue was resolved? If yes, glad to be of assistance and appreciate the rating. If not, pls post again that we may walk you through the input selection process.
    Cheer.
  • Louie  Role
    Hi again tomijean2,
    At your convenience, would you pls visually check and note down how the cable box is connected to the rear of the Toshiba. Knowing how it is connected would greatly simplify the source selection.
    Looking forward to your postback.
  • Louie  Role
    Additionally, may I pls inquire the brand and model of your cable box.
  • Louie  Role
    Alternately, you can try winging it.
    Selecting the video input source using the INPUT button which doubles as the ZOOM button (left side of the Channel UP/DOWN). Press INPUT to view a signal from another device connected to your TV, such as the Cable Box. You can select ANT, VIDEO1, VIDEO2 (on the front panel), ColorStream
    HD or HDMI depending on which input jacks you used to connect your Cable Box.
    Pressing INPUT on the remote control displays the current signal source. To change the input source, press INPUT again or press 0-4.
  • 3,037 Answers
1. you are on the correct channel or input correct?
2. Have you tried pressing the tv/vcr button on the remote
3. Have you tried shutting down both, unplugging them and seeing if something resets?
How did you notice this stopped working, while you were using the vcr or did you try to use it and it didn't work, please give me as much info on this as possible, thank you.
Is there sound at all?
  • 4 more comments
  • Benjamin Patri
    Benjamin Patri Apr 04, 2008
    everything else is working, all channels? have you tried pressing the button labeled TV/VCR or ANTENNA, because the screen may be that, The snowy screen has no noise when turned up?
  • Benjamin Patri
    check to see if the connection might have gotten lose somehow between the tv and the vcr
  • Benjamin Patri
    do any channels work at all on or off of the vcr?
  • Benjamin Patri
    I think a cable is lose and you should just try to push all of the cables in to make sure and hopefully this problem won't happen again. So the vcr/dvd works but now no tv channels are working?
  • Benjamin Patri
    maybe when operating the vcr, something knocked loose within the tv/vcr/dvd combo, and the piece of metal or whatever it was got back in place
    Is everything working now?
  • Benjamin Patri
    so dvd and vcr are working? that is good
    Are the channels from the cable box working?
  • 236 Answers
Have you tried changing the channel on the TV to channel 3?
Also, make sure your turn your VCR off, as it may be connected to the cable... Or, try turning your VCR to channel 3
  • 7 more comments
  • Dave MacPhee
    Dave MacPhee Apr 04, 2008
    did you turn off your cable box?
  • Dave MacPhee
    I should clarify that answer, I kinda said it like you were stupid.. I meant it as it is usually the most simple of things we overlook when we are trying to figure out a problem
  • Dave MacPhee
    it must be stuck in a mode.. I'm gunna look up the manual..
  • Dave MacPhee
    when you press the display button, in the top right corner, what is the channel on?
  • Dave MacPhee
    Another thought.. When you go into the menu, and select TV Setup, what is the TV/Cable set to?
  • Dave MacPhee
    * (you need to be on TV/VCR mode) for that menu
  • Dave MacPhee
    maybe try channel 2?
  • Dave MacPhee
    I would assume that you have taken out the VHS... Try pressing the stop button twice..?
  • Dave MacPhee
    if you put in a DVD, and change to DVD mode, does it work ok?
  • 871 Answers
Press the tv on the remote. if you want to use the vcr. press vcr on the remote.
SOURCE:
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I cannot get it to record a vhs tape to a dvd. The vcr will play tapes and the dvd player will play dvds. I need some one to walk me through what buttons to push to record.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Dec 20, 2010 | Toshiba DVR610 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Remove the vcr display from the TV screen in a Toshiba w-607 vcr
push the display button on your controller until the counter is gone
Sep 10, 2009 | Toshiba W607 VHS VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Vcr - dvd player problems
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
Apr 06, 2008 | Samsung DVD-VR325 DVD Recorder/VCR
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
DURABRAND TV 1907
use a sky remote you can tune it to your TV all buttons will be in the wrong place but they are there.
Nov 01, 2007 | Durabrand DU1901 TV
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
