Question about Car Audio & Video
Wiring up amp/installing amp
Can't find schematics for ava 400tr boss amp. Jensen MP6212 car stereo/boss ava 400tr amp. Amp is swapping over to protection mode.
Could it be a ground? PLEASE HELP :)
  • mar-t Apr 11, 2008
    Thanks for your help. After going back, I found that I had some speaker wires touching.
    Problem Solver:
  • 4 Answers
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Posted on Apr 05, 2008
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
I hook up a amp with red and black wire from the car stereo, then the stereo stopped turning on, why?
You probably blew a fuse. The power wires for a stereo can not handle the current an amp needs. An amp has to get it's power directly off the battery. Get an amp kit that has the power wire, ground wire, turn on lead, and fuse w/fuse holder. fuse the power no less than 12" from the battery.
Apr 19, 2011 | Boss MP3-3030R CD Player
I would just like to have the wiring diagram for the Boss AVA 9060 model. Thanks!
wires are: red-ignition, yellow-battery or memory, black-ground, blue-remote for amp or antenna, orange-illumination (if it has one), the white, grey, purple and green wires are the speakers
Sep 17, 2010 | Boss AVA-9060
I installed a sony x plode amp in a 2005 corolla which had a stock six speaker amp by jbl which came with car i also bought a jensen hd dvd radio i installed radio but need a wiring schematic to by pass...
If I am going to have a car and do a lot of audio installations, I try and order the manual for it. The manual usually has a full wiring schematic. You might call down to your local Toyota dealership and see if they can help you with the wiring schematic.
Also, you could just run new speaker wires. I know its a pain, but that is another alternative. With that being a newer car though I can understand not wanting to start tearing off internal moldings.
Aug 04, 2009 | JBL SCS145.5 System
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
Whinning noise when car is on and AUX is connected to ipod
ENGINE NOISE PLUG ALL YOUR RCA DIRECT TO AMP BYPASS EQ AND SEE WHAT HAPPEN IF THIS STILL HAPPEN CHECK ALL YOUR GROUND AND RCA MAKE SURE YOU HAVE GOOD CONNECTION
Mar 30, 2009 | Boss AVA-1215 5-Band Car Equalizer
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
Car stereo wiring diagram
Main power wires
Yellow to constant always on power
red to accessories
black to ground
blue if you have an amp this will be remote wire if you dont have amp then just cap off
the other wires are as follows
top section speaker wires right and left
bottom section speaker wires right and left
the speaker wires come in colors like purple purple line
grey grey line
orange orange line
white white blueline
these are your speaker wires simple just remember power lines grounds
May 03, 2008 | Boss 510CA CD Player
Connection
schematic & instructions on deck red (+) - power - 2 amp's power inlet power (+) black (-) - ground - 2 amp's power inlet ground (-) deck yellow wire - remote - 2 the remote amp deck outputs 2 the RCA amp inputs amp RCA outputs 2 speakers it is wise that a pro will install the system it will give u less concerns and u will have warranty on the installation this will save u the money u will spend for fixing a bad installation
Feb 03, 2006 | Jensen A300HLX Car Audio Amplifier
Car Audio & Video Logo
377 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
