2003 Suzuki RM 125 Logo
A
Anonymous Posted on May 19, 2010
I have a 2001 rm 125 im trying to rebuild the bottom end on. Do I need a special tool to split it? i have all the bolts loose and it wont come.
Danny
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Sep 12, 2010
Danny
Expert
Level 2:
Scholar:
Answers
127
Questions
Helped
55231
Points
318
Yes, you need a special tool to split the casses and a tool to remove and install the crank...
2answers
My rs 125 will start but not run
theres somethin in the transmission or drive thats doinit--need a bottom end inspection or rebuild of gear area--get a repair book online-u need special tools and technique
Splitting the case on an 02 rm 125 got all the bolts visible on outer case just wondering if theres bolts under the clutch housing to be undone before i split
Normaly you can remove the left crankcase on its own, however if it is proving difficult to split it is possibly tight in the crankshaft main bearing, you will need to remove the clutch at some point during this rebuild so do it now while you have the stability of the engine cases , undo the nut securing the crankshaft pinion on the r/ h side, the crankshaft is often easyer to remove from this bearing, also it is easyer to reasemble the engine and gearbox when previously dismantled correctly. Paul
1helpful
My 98 rm 125's water pump seal is leaking and it needs a top end rebuild are their any good online guides or videos to help me do it?
9003904_rm125__thumb.jpg 5.00 USD
Suzuki Rm125 Service Manual Repair 2004 Rm 125
Instant download of the official manual for the RM125 2 stroke bike. Specifically for the 2004 model, but can also...http://www.tradebit.com/filedetail.php/9003904-suzuki-rm125-service-manual-repair-2004-rm
I hope that this helps you and please do not forget to rate/vote and place a testimonial on my advice.
Wicked Angel
Gear lever doesnt click - cant change out of 1st
The problem is a bent shift fork. Best to have the shop do the repair. Most riders don't have the special tools needed much less the know-how to do the repair. The entire engine comes out then gets completely torn down, top end and bottom end. The center case splits and now the mechanic has access to the gears and shift forks. You will have at least 100 parts on the work bench. This is not generally a job for the home mechanic.
2answers
Having trouble getting the bottom end apart
there may still be something that needs to be removed from the sides. check again. if all clear, close and pull open quickly several times to pop it off
2answers
1996 rm 125 has clutch problems. The quater inch play does not work, new cable, aftermarket clutch with springs,fibers,steele.
Did you check the main crank drive gear i had a 96 rm 125 with that problem. Its a cheap fix if thats the case but the only problem is that the engine needs to removed and the case needs to be be split. If thats not the problem with the case split it should be ovious.
1helpful
How do i fix the main bearing on a suzuki 125rm?
a manual is recomended and yes you will have to split the case and remove all of your gears you will also need some special tools to pull things appart do not attempt this without a manual and make sure not to put gears in the wrong spot when reasembeling the motor, good luck I have done several main bearings in bikes I have owned over the years it is not a job for an amature mechanic. no offence
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
