Question about Cell Phones
My battery drains and when I try to connect on my car charger it fails. My home charger also fails to give it some charge. After a long while and many attempts, the charge starts coming in.
    Problem Solver:
  • 10 Answers
Take it to your service provider tech. They may have to change the charging plug .
Posted on Apr 04, 2008
SOURCE:
Battery was low 1% plugged it in was charging, left came home couple hrs. Later! Now won't turn on, won't do anything??
remove the battery press the power button for more than 10 seconds then release and repeat the process, then insert the battery and connect the charger again wait for sometimes. Hope will help. If fails you have a drained battery try busting the battery.
Nov 23, 2015 | Tablets & eReaders
My iphone has been charging for almost two days now and hasnt left the black charging screen
do an SMC hard reset by holding down power button and home button until the device restarts, keep holding till apple sign appears and plug into itunes. (recovery mode)
Jun 17, 2015 | Apple iPhone 5
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
I've tried this charger on 3 batteries and always get "check connection" light, and flickering "battery charged" light. I've pinched clamps and connections are very good...I've left...
Smart chargers will fail to charge completely discharged battery. Simple charger w/o electronics will. Try connecting two batteries together with charger. ALL in parallel. + to +, and - to -.
Mar 03, 2018 | Minn Kota MinnKota MK110P Marine Portable...
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
My phone will not charge even with a brand new battery
You may have a defective charger. If you are using a home charger, try using your car charger to charge your phone. If you're using a car charger, try using a home charger. If neither works, you may need to try another battery.
If all of this fails to charge your phone, you may want to consider sending it back for repairs or replacing your phone with a new one.
Jan 24, 2011 | Cell Phones
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Blinking and Whining
I had this happen, and I solved it by connecting it to the car charger for a while, then bringing it in and connecting it DIRECTLY to the AC charger for a full charge. (This assumes the battery is not just kaput.)
Here's what I think happens: The AC charger doesn't have enough current capability to run the unit by itself AND keepp the battery charged (bad design), so, if left continuously ON, the battery will eventually drain. In this state, if you shut it off, the unit senses a low-battery condition and will try to charge, but the charging circuit tries to draw too much from the AC charger and the voltage droops (causing the whine) to the cutoff point (causing it to stop charging, another case of bad design). The car charger has more current capability, so it gets the battery charged enough to use the AC charger again.
Nov 28, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
