I was watching VCR's and now I can't get TV picture, I must have pushed a wrong button.
  • 927 Answers
Try turning the vcr OFF or try change tv's inputs, if not give more info.
Posted on Apr 04, 2008
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
Aug 05, 2009 | Panasonic Televison & Video
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Sony tv
let me know what were you watching at time of pushing button on remote?
was it TV program or dvd player / vcr movie some thing?
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
