Question about Dryers
There appears to be water leaking from my dryer?!
    President:
  • Dryers Master
  • 2,651 Answers
Ohhhh thatrs never a good thing!!!! you have an issue with a clogged vent!!!! its trying to remove the moisture from your clothing but your vent is clogged and backing up into the unit.. replace or at very least have it cleaned out from end to end as soon as possible!!!!
Posted on Apr 04, 2008
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
There is water coming out from under the dryer. I have checked and there is nothing wrong with the washer.
Check and insure the vent is clear. A clogged vent will prevent mositure from leaving dryer, as this moisture builds it will pool at the low spot or appear to be leaking from the dryer. A second possibility which I am sure you have already checked is that the clothes are not being thoroughly rung out in the wash cycle. If they are dripping wet when placed in the dryer, access mosture could leak out as well.
Mar 02, 2011 | Kenmore Dryers
Water under dryer after use. cleaned exhaust lint in it was wet. should i insulate exhaust tubing. fsminatrea@yahoo.com
Hi
Dryer would be either leaking from vent or due to condensation. The vent may either be blocked. The water is coming from the clothes you have dried in the dryer and it has no where to go.
You need to dismantle the vent and clean it, replace it with new vent. The dryer may now be consuming more time to dry the same load of clothes. By correcting the venting problem you will solve the water problem and shorten your wash day and save on electricity as well.
Another issue is condensation which usually appears on the dryer vent pipe colder climates. As the warm air from the dryer is vented to the outside, it must be protected from the cold temperatures outside. If your dryer vent pipe is not properly insulated, the air that is being vented out will turn into water when it comes into contact with the cold pipe outside. This results in condensation and dripping water. To resolve this, you must insulate your dryer vent pipe along its entire length. This will ensure that the hot air from the dryer does not undergo temperature fluctuations, and no water will leak into the vent pipe. Hope this helps... Please post back if you need more information.
Danile
Dec 27, 2010 | Maytag Dryers
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
574 people viewed this question
Top Dryers Experts
