Question about Lexmark X1270 All-In-One InkJet Printer
Can't get printer to work on vista
I went from a xp to a vista and can't get my Lexmart x1270 all in one to work. I download the software from the disk and then it says it is ready. But every time I try to print something out it says, problem communicating with printer.
Everything is connected. Help me, PLEASE!!!
  • mjbled Apr 04, 2008
    Your lucky you're not near by because if you were, I'd kiss you. Thanks a lot. That fixed me right up.
  • 110 Answers
The disc (CD I presume) may not have the latest drivers on it for Vista.
Download the latest drivers from the Lexmark website and install them.
Posted on Apr 04, 2008
All printer drivers are available online, through the manufacturers website.
In your particular case, the drivers can be found at:
You just have to navigate your region and language, then search for your particular printer model. You will have a choice of drivers for each of the common platforms (XP, Vista, etc.)
Aug 13, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer is new but I didn't get the startup disc so I can"t use my printer . the printer is a lexmark x1270 all in one . the printer turns on but will not print. I have the usb port cable but no start...
If you are using Xp use this link and paste it in the address bar and you will get the file to download.
And for Vista
Hope this Help.
Jul 17, 2009 | Lexmark X1270 All-In-One InkJet Printer
Re-connectionmto Windows XP
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select the operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Feb 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
My lexmart want work with my vista
go to and in the search box type in "6170" and click on the search button.
It will bring you to the page for you lexmark x6170 printer. scroll down and in the drivers and downloads section click on windows vista.
Then on the next page in the recommended downloads area click on the tab that says windows vista. There will be a name of the file you have to download. Click on the download button and let the file download.
Once the download is done, double click on the filename which should be cjrx6100en.exe. Let it run and it should install the software and have your computer recognize the printer.
Hope this helps.
Feb 10, 2009 | Lexmark C533DN InkJet Printer
I have a printer lexmark x1270 all in one need to add the printer but don't have the cd to install the printer
The Lexmart webite will have the software & drivers available for download in their support section. All you should need is your model # & the operating system that you are using in order to download the correct drivers. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
I cannot load the software drivers to my Lexmart X6570 printer. It will make a straight copy but will not print from the computer or scan. I have tried the CD that came with the printer and tried to...
hi is the pc your on xp or vista ?
some printers are not compatible on vista if this is what your using there is however a fix for this go on the net and down load a program called driver genius 2007 pro this will find any driver problems on your pc sys and down load the drivers to fix any problems on you pc complet .
hope this helps ok thanks
May 22, 2008 | Lexmark Office Equipment & Supplies
How to install my lexmark x1270 without a cd
The only way to setup the printer without the proper drivers would be to use windows add new printer. However windows does not have lexmark x1270 listed. You can dlownload the software from lexmark & install the software / drivers without using the cd.
You need to choose your version of windows to continue.
This next site will show you how to connect your x1270.
Also listed is the user's guide manual.
Hope this can help you.
please vote
Feb 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark printer
you have to go on lexmark and download new software i just went through the exact same thing i have windows vista .the soware that comes withthe printer is not compatible with vista or xp i wish i new how to give you the link but i don't have it anymore.anyways if you get the new software on line it will work perfectly
Nov 30, 2007 | Lexmark X1270 All-In-One InkJet Printer
Cannot get t180 to talk to the printer Lexmart x6100
check that the driver that is on the cdrom is vista supported and not XP as this will cause problems, the printer that is set at default may not be the lexmark, so check in the printers menu that it is actually listed.
Try here for a driver
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
Lexmark X1270 All-In-One InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
