Question about Cameras
Zoom will not go back when i power off, comes up zoom error
  • Anonymous Oct 07, 2008
    My camera also does this. I have never had a problem before and suddenly I get "zoom error"
  • Anonymous Jan 07, 2009
    i have the same thing. it has never done this before but now i as well have "zoom error"
    anyone know how to fix thissS?
My camera was dropped and the zoom small stick stop working, looks like it was stuck, when I want to zoom I pull de stick but it doesnt work, any suggestions?
Posted on Oct 27, 2008
How do i factory reset my panasonix lumix dmc-fz45
Remove the batteries for 60 seconds, at the same time press power and hold for the juration of the time, this will remove residual voltage and reset the processor ic, "long shot" if no change the zoom part of the lens is malfunctioning, the zoom motor or gears are jammed.
Apr 04, 2012 | Panasonic Cameras
Fujifilm A345 keeps saying zoom error lens wont open and when i press shutter button it makes a short buzzing sound then zoom error comes up help
I recently came into this camera and after a day of testing it, it's doing the same thing. My work around is this. When it's on I press the zoom function and the lens then pops out. Then after it's out, I remove the batteries while it's still on. Put the batteries back in, and power it on (lens will be popped out) and then it starts working. I only paid $7 for it at a good will. So I was taking a chance it worked somewhat. This may work for you temporarily. Not sure how long this one will last.
Oct 11, 2009 | Fuji FinePix A345 Digital Camera
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Zoom error
look for a tiny pinhole and insert a pin while powered up to reset...if this does not work, if you get to the point to see any electric motor, then apply a battery powered set of jumper wires to the motor to manually run the zoom back and forth. start with one battery (1.5 volts) only!
May 27, 2007 | Fuji FinePix 6900 Zoom Digital Camera
Cameras Logo
181 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
