Question about Whirlpool Duet GHW9150P Front Load Washer
Front load dryer shoe rack
How do I put in the shoe rack for drying without it bumping against the inside. I didn't get a manual on the dryer whirl pool duet this is the dryer not the washer!!!!
  • Anonymous Mar 18, 2014
    My dryer didn't come with a manual or drying rack. How do I use the air dry feature without the rack?
    President:
  • Whirlpool Master
  • 2,651 Answers
    New Friend:
Dear Sir/Madam ,
kindly let us introduce ShoesMate with the excellent functions of shoes
drying, deodorization and sterilization.
ShoesMate
DC 12 Voltage adapter & code plug are included.
Colors : red, silver and navy
Functions : Sterilization, Deodorization and Drying.
---Excellent Function for Shoes Dry, Deodorization and Sterilization
by the Far-Infrared Rays.
---Effectiveness for Athletes Foot Prevention and Bad Odor Reduction.
---Simple Operation by one-touch switch on & off.
---Shoes are keep in shape as they are without being deformed.
---ShoesMate is automatically off in 4 hours.
---DC 12V Adapter in use.
---Elegant Design.
---Design Registration to Korean Intellectual Property Office: 30-0528270
you feel comfortable in shoes after using ShoesMate. please get more
information and photo image from our website http://www.umbrellawrapper.com/
Posted on Jun 17, 2010
That was great-- but-- it fails to mention where that wire is---it can be adjusted-- and you can move the arm that has to rest on the very back of the dryer. My wire arm, must have fallen out and then it seemed like it was just too small! Now I moved it to another side hole and and YEA! its working! make sure its long enough to hold onto the very back---:)
Posted on Oct 08, 2008
    New Friend:
You might want to try The Dryer Shoe Holder. The Patented Shoe Cleaning System to Wash and Dry Shoes. See it work here: www.J5Enterprise.com front load dryer shoe rack - b5b7a88.jpg
Posted on Jan 25, 2010
SOURCE:
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I clean shoes made fom fabric?My shoes are a light beige color, almost white, made from fabric. Bought them at Payless Shoe Source Can I wash them in the washing mashine? If yes, how? Wht cycle? DO...
When fabric is of canvas material they can be washed in the washer, suggested detergent to use Baby Shampoo as it is much more gentle on the fabric. Use warm water only as hot will shrink as it does with clothes washed in hot water will also make them stiff and brittle, baby shampoo will also lend a nice scent which will remove any shoe odors noses could detect short wash only, do not dry in dryer without a rack as the tumble action can damage the rubber sole, best if dried in a warm room or outside not in direct sunlight as sun can damage the fabric, best very warm day for drying Good Luck !
Oct 27, 2010 | Clothing Accessories
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Aug 30, 2010 | Whirlpool Duet Front Loading Dryer Rack...
What is the rack for
The rack is to dry things like sweaters or shoes that you would not want tumbling around. When used the items are stationary and the drum rotates around them. Low or no heat can be used to facilitate drying without shrinkage or damage.
Eric
Jul 15, 2010 | Maytag Dryers
How do i install the shoe rack in the dryer
It is a trapezoid, the wide end goes toward the door and lines up with the lint trap. You cannot support two boots, or heavy shoes. It just balances in the rim of the door frame. The handle shaped things face down. You kind of have to pinch it into place, and it just rests there, too much weight and it will topple in. Good luck if you have big feet.
Sep 27, 2009 | Kenmore Dryers
Install shoe drying rack gas dryer
I am in dire need of the Fisher & Paykel Dryer rack Model # DEGX1. I now have a two year old who loves Mud puddles and I would love to be able to buy the Dryer rack. If you know where I could find one. could you please contact me @ [email protected]
Mar 22, 2008 | Dryers
Dryer rack installation
I had the same problem: they sent me the rack, but no instructions.
But if you look in the product manual for your dryer, there should be a section on how to use the rack. For the Cabrio, which is what I have, it's on page 21.
If you don't have the manual anymore, you can get them online at Whirlpool's web site. Just plug in your model number in the search box, and there it will be.
Feb 26, 2008 | Whirlpool Cabrio WTW6600SBK
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
7,622 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
