Question about Xerox Office Equipment & Supplies
Xerox C2428 has error 010.422. Please advise if this is fuser related. If not please advise what it is and what I need to do to repair this unit for my client. Regards, Ken Holmes.
SOURCE:
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
SOURCE: dell 3100 error 010-397 restart and reseat fuser roll
We had the same problem. I loosened the levers that hold the fuser in place, and the one on the left side (as you face the printer) came out. When I put it back in, it didn't click into place all the way and the error message came up. I pushed down slightly on the fuser, then pushed the lever toward the back of the unit about as hard as I dared until it clicked back into place. That locked the fuser into place properly and resolved the problem.
Posted on Oct 06, 2008
  • 990 Answers
SOURCE: Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
Posted on May 16, 2009
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
Error code 010-327 on my Xerox Workcentre Pro 128 photocopier. How easy is it to change the Fuser unit on it? Does it have to be done a professional photocopier technicien? Please advise
Xerox is famous for not letting parts to amateurs, but here is a site that may help. Had a 5035 for years and changed the fuser lamp. Not that difficult on that model. PARTS for Xerox Brand Copiers
Mar 07, 2018 | Xerox Office Equipment & Supplies
Xerox 7242 error 010-328 i have a xerox workcenter 7242, it is giving me error code 010-328. how can i fix this error please
That error points to a fuser problem. Replace the fuser and see if that works for you. If not then you need some add'l parts and a service tech to install and repair it for you. Hope this helps.
Sep 03, 2016 | Xerox WorkCenter Office Equipment &...
Errore u60 per stampante phaser 7400
Dear Tonifot, Welcome to Fixya Support.
Error U60 is related to Fuser Unit.So check inside the printer whether any paper pieces or any obstacle which preventing fuser unit roller movement. If no obstacles,this means your fuser unit is dead and you have to replace fuser unit to work normally.
I think it helps, Let me know.
Dec 16, 2010 | Xerox Office Equipment & Supplies
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Hello, i have a canon xerox machine ir3300 model. I have a problem in Error Code. The Error code is E000000-0000. Please tell me how to solve this problem. my e-mail id is: [email protected]
There is a problem in the fuser area of the copier. For some reason the fuser is not heating to the proper temperature. There are several possible causes such as a failing/failed thermistor (this is a heat sensor device that monitors the fuser's temperature) or a thermal switch (this is a device that, based on the current value of the thermistor, either turns on the heating unit or turns off the heating unit) or the heating element itself could be bad, etc etc etc
Unless you are a technician with extensive Xerox experience I will advise you to contact Xerox about tech support.
Oct 07, 2009 | Canon Office Equipment & Supplies
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
I have a xerox 5016 copier ,
All U4 codes on Xerox machines relate to the "fuser".( That's the hot bit on the way out) You will find the rollers fail to warm up, or reach correct temperature .
Most often the heater rod inside has burned out, or sometimes the overheat thermostat goes open circuit.Both problems will require the fuser unit pulling out of the machine and a test meter to check continuity of the components
Jan 07, 2008 | Office Equipment & Supplies
Open Questions:
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
