Question about Mitsubishi VS-55705 55" Rear Projection Television
Mitsubishi vs-55705 input B003 does not receive signals
  • brnsern2465 Apr 04, 2008
    no signal on B 003 input for cable reception
    Scholar:
  • 77 Answers
Well the "B" is the B tuner make sure you have the cable on the "B" input on the back of the set. If so, does the "A" work? If the A works then you can just use it and you probably have a bad tuner in the TV but you have 2 in this set. If niether work you've got problems. You might check the Home theater settings in the menu under A/V reciever. Mitsubishi used to lock the inputs to a certain input or channel for use with a monitor out on a reciever. If none of this helps better get a pro to look. Good Luck
Posted on Apr 04, 2008
Mitsubishi VS-55705 error code 12
"12" is no error, no problem. Also, if you unplug TV power, you lose all errors in memory.
Apr 26, 2014 | Mitsubishi VS-55705 55" Rear Projection...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
What is the dpi of mitsubishi vs-55705
Native resolution of the set is 720p 1366 x 768
Jan 15, 2011 | Mitsubishi VS-55705 55" Rear Projection...
I HAVE A MITSUBISHI VS-55705 AND THE CENTER OF THE SCREEN HAS A PERFECT PICTURE AND THE SIDES CURVE IN AND THE OP AND BOTTOM CURVE IN. wHAT IS THE PROBLEM?
THIS is a 1999 model VZ7 chassis and it uses two of the STK-392-110 CHIPS FOR CONVERGENCE.
If picture looks 3d or bowed with colors out of place or around letters etc, the chips need to be replaced.
I will attach photo of what the chips look like--one used here is the most popular one and used in many brands of sets.
Total parts cost for a pair will be under 20 dollars and repair takes about a hour.
If the picture or information I have provided told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
This is from a Hitachi but your set uses the same two black chips.
Aug 22, 2010 | Mitsubishi VS-55705 55" Rear Projection...
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Sound but no picture on a Mitsubishi VS-45VA2.
This is the VZ1 Chassis.. CHECK FOR 1200 VDC AT PIN 1 OF CONNECTOR "DK". IF LOW OR MISSING CHECK R5D9 100 OHM 1/2 OFF PIN 1 OF THE FLYBACK ON THE MAIN PCB. 2. CHECK IC401 PIN 8 FOR 28 VDC IF MISSING CHECK R510 1.2 OHM 1/2 W OFF PIN 5 OF THE FLYBACK. IF OPEN IC401 PART # 272P239 If those voltages check out let me know and we will go to the next level. Two other questions do you have video through the pip with the alternate input? and do you have on screen display when you push menu on the remote?
Feb 16, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi vs-45va2
Can you be more specific? What kind of distortion are you talking about?
Jan 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Model # vs-45va2
Does it operate at all, or does it start to power up then shut down?
Oct 19, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
