Question about HP LaserJet 4250n Printer
Blank display my HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on... what is the problem?
  • KTech May 20, 2008
    my Hp LaserJet 4250 printer is printing but the display screen is blank.
  • KTech May 21, 2008
    my HP laser jet 4350n printer turns on but the display screen is blank
    New Friend:
  • 159 Answers
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Posted on Apr 05, 2008
  • jf27 Jan 19, 2011
    Mine needed a small memory card reseated.
  • jf27 Jan 19, 2011
    I removed the left-side covers as if I was going remove the EIO, but seeing the small memory card I removed it, reseated it, and all started working. Cheers all around.
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
    Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
    Sep 29, 2011 | HP LaserJet 4250n Printer
    51.2m error
    This is a problem with the magenta cartridge in your printer. According to hp's website, you can try the following to fix it:
    2. Turn the printer off, and turn it on again.
    3. Perform a cold reset.
      5. Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    4. If this message persists, contact an HP-authorized service or support provider.
    Hope this helps
    Please rate this solution, thanks!
    Mar 09, 2011 | HP Color LaserJet 5500 Printer
    Code ereur 59
    A code error 59:
    Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
    1. Press the green c00099346.jpg (Select) button to continue.
      3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
      4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
      7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Mar 02, 2011 | HP LaserJet 5550DN Printer
    HP 5500 can not print with 59.CK error code on display
    You probally need to contact an engineer on this one, from HP trouble shooting manual
    Description
    Action
    1. Press the green <Tick Symbol>(Select) button to continue.
    a. Turn the printer on.
    b. Watch the control panel.
    c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
    d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    f. Press (Down Arrow) button once. The control panel will display COLD RESET.
    g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Sep 22, 2009 | HP LaserJet 5500 Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    49.FF95 SERVICE ERROR
    Please look on: http://www.fixyourownprinter.com/
    There are much solutions of this problem listed ...
    For example this (it see good):
    http://www.fixyourownprinter.com/forums/printer/46157#1
    HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
    Anybody know the error code "49. FF95 Service Error"
    We can't get around this...
    Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
    It could be a bad job.
    First disconnect it from your network and any PC it might be attached to.
    Power cycle it, then if it goes to ready status try the built in test pages, do they work?
    If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
    More reading:
    http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
    Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
    Still won't go back to ready status. Turns on to the same error code....
    Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
    Try a cold reset, it will reset the JetDirect settings, but it's the next step.
    Cold Reset:
    Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
    Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
    Thank You so much for your help... but that didn't work either. Same error code showed up.
    Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
    Then you probably need to replace the formatter.
    Do you have another printer you can swap parts with?
    There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
    A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
    These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
    A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
    Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
    I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
    Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
    You might also try disabling the embedded JetDirect.
    To disable the embedded LAN port
    Turn the printer power off.
    Power on the printer and watch for the memory count to begin.
    Hold down the SELECT (Checkmark) button, when you see the memory count begin.
    Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
    After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
    Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
    If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
    Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
    The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
    The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
    If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
    Regards
    Trev
    Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
    hi.
    With a cold reset ,my problem solved.
    try this as a first solution.
    thank you
    Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
    THANK YOU WERY MUCH
    FROM TURKEY
    ZAFER
    Jan 02, 2009 | HP LaserJet 2420dn Printer
    Printer problem
    First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
    May 21, 2008 | HP LaserJet 4250n Printer
    HP LaserJet 4250n Printer Logo
    1,595 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
