Question about Sony Playstation 3 (PS3) Console
After formating PS3
I did a quick format o my PS3 and it said to connect the USb to the controler and then press the PS button but nothing happens
  • 21 Answers
You need to plug your sixaxis controller to the ps3 with the usb cord to marry the control to your system. after unplugging and pressing the home button it should link up. If not try using another usb cord or plug on the ps3.
Hope this helps.
Posted on Apr 04, 2008
I have a ps3 dualshock 3 controller that wont connect. i have taken it apart to check and see if anything was wrong with the inside, but i saw nothing. When i put it back together, i tried pressing the ps...
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 13, 2011 | Sony Dual Shock 3 Controller for...
How do you format a ps3
Ok, follow these simple steps :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep once when you press it, once more 5 seconds later and then once more and it will turn back off onto standby. Release the power button.
Step 3. Press and hold the power button again. It will beep once when you press it, beep again 5 seconds later then it will beep twice quickly. When you hear these 2 quick beeps let go of the power button.
Step 4. Your PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go on to step 5.
Step 5. A menu will load up. Select option 5 "Restore PS3 System". This will format the PS3 and reset all settings back to default.
Hope this helps and thank you for using FixYa
Aug 27, 2010 | Video Game Consoles & Games
Hard drive cannot format
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I wish you good luck.
Comments:
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
No sound, now the conrtoller doesnt connect
You gotta hook the controller back to the system via the usb cord and then press the PS button. Finish the format.
Let me know if you still have problems afterwards.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Ps3 controller wont connect to ps3
-Press the tiny reset button on the back of the controller
-Plug in the USB Connection wire
-Restart Console
-When loaded, Press the PS Button
Hope it works mate :)
Mar 15, 2009 | Sony Wireless Controller for PS3
Problem with ps3 controller
Try hard resetting it by doing this:
Flip the controller over, and press the reset button. It's to the right of the middle-top screw ps3_controller_reset.jpg. You'll need something like a paperclip, toothpick, or something similar to push the button. Once you've reset your controller, connect it to your PS3 with a handy USB cable, and press the PS button (just like you did when you first got the controller). Now, it is paired again, and you should be OK.
Best of luck!
Feb 25, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
134 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
