Question about Texas Instruments TI-83 Plus Silver Edition Calculator
Maths graphing when i want to draw a graph, it gives me a dim mismatch..is there any thing wrong with my calculator
  • Texas Instru... Master
  • 7,993 Answers
Reset the RAM and try again. To reset RAM press [2nd][MEM][7:Reset] [All RAM] [2:Reset]
Hope it helps.
Posted on Sep 22, 2009
When trying to write simple graph lie Y=x+3 i get err: DIM MISMATCH QUIT
Dimension mismatch error occurs when arguments are not with same dimensions. Two or more arguments must be of the same dimension. For example, [1,2]+[1,2,3] is a dimension mismatch because the matrices contain a different number of elements. By the way, it it very easy to resolving your problem with graphing linear function. See captured image
Sep 22, 2011 | Texas Instruments TI-82 Calculator
Won't Graph Exponential Function
Ok, try these two things and you should be just fine.
1.) Check your range for your graph. It is possible that the range you are using isnt large enough to show the curve. Also try using Z-fit vs Z-st. These are options that your calculator will give you once the equation is graphed.
2.) Place a parenthesis around the 2x, make sure that you and the calculator are both using the same order of operations. This move mill ensure that the calculator will multiply the variable, x, by two and then do the exponential.
This should do it!
Happy Graphing!
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
When i try to look at the graph i've given the expression in "Y=", the calculator wrote on the screen "ERR:DIM MISMATCH" How can I manage to look at my graph then ? What's the preblem ?
Reset the memory of the calculator and draw your graphs again.
To reset memory
Press [2nd][MEM][3:Reset][2:Reset][ENTER].
Since this procedure resets the screen contrast to default settings, you may have to adjust it.
To adjust contrast
Press [2nd] key and release it.
Press and hold [UpArrow] to darken or [DownArrow] to lighten contrast.
Hope it helps.
Nov 15, 2009 | Texas Instruments TI-82 Calculator
TI 84 plus problem
Reset the calculator RAM and retry. Some old configuration settings are giving you the error.
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-84 Plus Calculator
Dim mismatch
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features..
Jun 18, 2009 | Texas Instruments TI-82 Calculator
Dim Mismatch
That is because you don't have the right amount of points. Either delete one point or add another point. Then try to graph it.
Jan 10, 2009 | Texas Instruments TI-84 Plus Silver...
Getting a DIM:MISMATCH when i want to draw a graphic, tmmrw exam
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 07, 2008 | Texas Instruments TI-83 Plus Calculator
Graphing Lists on TI-83
Make sure you have the same number of points in the two lists.
Oct 22, 2008 | Texas Instruments TI-82 Calculator
Dim Mismatch
Hit 2nd then the Y= button and you'll get to the stat plots. make sure they are all turned off, sometimes random programs (ie. games) will turn on stat plots and screw up your other programs and graphs.
Sep 25, 2008 | Texas Instruments TI-84 Plus Silver...
Dim mismatch error
Hello matilda. The Y is your vertical & X is horzonial. With TI-83PULSE you should aquire a 'V' on the graph with point of V at center cross with Y=X^2. You can't aquire a Y=Y1+X^2
May 18, 2008 | Texas Instruments TI-82 Calculator
Texas Instruments TI-83 Plus Silver Edition Calculator Logo
287 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
