Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Lynksys is causing high blood pressure
I connected to road runner today and had to switch which computer had the lynksys router and adapter. i can not for the life of me get the adapter computer to recognize the internet. i know my settings have to be messed up but lynksys is of no help to me unless i give them $33. Please help female near tears.
    Sergeant:
  • 202 Answers
Hello cyndilynn
OK, my friend, don't fret. Let's find out what the skinny is. First things first...
(01) Do you have the manual for your router?
If not, you can download it from HERE.
(02) Do I understand you correctly that you are able to connect to the Internet from one of your computers and not the other WHILE using the Linksys BEFSR41 router?
Some points to clarify:
(A) Your Linksys router (connected between your cable or DSL modem and your computer(s)) and your Linksys NIC (installed in your computer) are two different animals that serve different purposes.
(B) Your router should be connected to each of your computers via "straight through" (not "cross-over") Ethernet patch cables that run from the LAN ports at the back of your router to a NIC connection on each of your computers.
(C) The NIC and the ROUTER do not have to be made by the same manufacturer (in this case Linksys). Manufacturer's NICs and ROUTERs can be mixed and matched just fine.
I suspect the issue is w/ detection of your NIC on one of your computers. I doubt the issue has anything to do w/ your router.
If that is the case, please, provide details about the two desktop computers that you have tried the Linksys NIC in (one successfully, one unsuccessfully).
(03) What operating system is each computer running?
(04) Has the computer that you have been unsuccessfull connecting to the Internet through the Linksys router ever been successfully connected to the Internet?
For now, please, answer these 4 questions and provide any other information you can think of (the more details the better). Then we'll move on to the next step.
Thank you
BJ
Posted on Apr 04, 2008
  • Anonymous Apr 04, 2008
    While you're at it, would you, please, provide the model no. of your Linksys NIC?
    Thank you
  • Anonymous Apr 17, 2008
    Hello CyndiLynn
    How did it go? Did the information and links I provided you w/ enable you to get your network and Internet issues resolved OK?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to assist you.
    If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
6ya staff
SOURCE:
Trying to add my MacPro to my lynksys network.
if your linksys is set for dhcp,make sure your mac is set for dhcp.
if everything is set and problem still persists,reset the linksys.
Oct 27, 2012 | Linksys Lynksys Etherfast 16-port Ethernet...
I have a lynksys router. It will work with our mac, but if i try to get online with my pc, neiter will connect or if one is connected, it will disconnect. can i fix this
I see that you are having issues with your network connection, I believe that you are trying to connect wireless on both systems.
* Check your Linksys for settings that limit the routers wireless connection, most wireless routers have an option on how many computers can connect wireless to the router, a wireless signal does not chose what OS to allow for a wireless connection.
* get in your Linksys Routers Setting page from IE or Firefox using your Default gateway IP from there on you can check your Routers settings, user name depends if your internet service provider changed the Routers user name and password but for a Linksys try admin / password or admin / admin for the User name and Password field.
Hope this helps you thanks and have a good day.
Mar 30, 2011 | Cisco Lynksys Dual Band Wireless N Gigabit...
We have a lynksys router. It is 2 years old.
upgrade the router to the latest version of firmware and reconfigure the same.
Also remove the existing saved connections from ur computer and then readd the new connections after reconfiguration of the router.
Jan 11, 2010 | Linksys WRT54G Wireless-G Broadband Router...
I have a Lynksys Wireless-G brand WRT54G2 router connected to my High Speed Ethernet Modem and to my desktop computer. It puts out a fairly decent signal to my laptop across the house through walls and...
Yes. 1. Disable the DHCP in the belkin router. 2. Take the cable from the LAN port of the Linksys router to the LAN port of the Belkin Router. 3. Dont touch anything else in any of the routers.
This should help
Thanks Ranjit
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Cannot Communicate from Computer to Computer
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
Good Luck
Gus
Nov 18, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Connecting wireless router to laptop computer
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
