Question about Cameras
In shooting mode with Fugifilm 5000, only purple, green and white abstract colors show. Tried everything, but to no avail.
  • Cameras Master
  • 19,396 Answers
If you get this in the pcture you may nee to change the sensor. You should contact the nearest service in your area
Posted on Apr 04, 2008
  • Ginko
    Ginko Apr 04, 2008
    Here is a forum with loads of people with same problem. Fuji charges over $150 to replace the sensor.
    Ensure that is not the display, if it is a display problem the pictures will be ok when downloaded into pc, and you get colors only on lcd display. If pictures also show weird colors, the sensor is probably faulty.
SOURCE:
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 09, 2018 | Heating & Cooling
What are the corresponding values to the colors of poker chips?
the standard values for the poker chip colors are as follows
White, $1
Yellow, $2
Red, $5
Blue, $10
Grey, $20
Green, $25 sometimes green is also used as a $20 value
Orange, $50
Black, $100
Pink, $250
Purple, $500
Burgundy, $1000
Light Blue, $2000
Brown, $5000
Oct 08, 2013 | Games
My hp printer casts purple to black and white prints
Tried your settings with no luck. Also tried every canon profile listed to no avail.
These are my settings:
Color management:
Color handling: Photoshop manages colors
Source space: sRGB...2.1
Printer profile: Canon MP620 Series GL2/52G
Rendering: Perpectual
Media Type: Glossy Photo paper
Print quality: standard
Effects: borderless
Printer Preferences:
Color Intensity: manual-set-everything is 0-matching:none
I am using Kodak glossy paper and I am using that setting. I am printing a digital scrapbook page with color. I used black and white pictures in the page trying to get rid of the purple trees, so it shouldn't be printing any color at all in the photos, but the limbs are still purple.
Under color settings in PSE I have checked "optimize for printing".
I am off to the store to pick up another package of photo paper..maybe HP or Epson will be better (I think those are the other 2 choices in the store)
Will check back in after I try the other papers
Aftermarket car headlights
Jun 11, 2012 | Office Equipment & Supplies
Too much purple in sony bravia
Try to examine the screen with the color turned off---is it a uniform color other than gray or black and white?
A photo posted somewhere with a link showing what it looks like might be helpful.
May 15, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
Red Color not working
Does this only show up in one connection IE: HD cable box, DVD player etc, If connected to a HD cable box a loss of red can mean a defective red component cable.
Aug 15, 2009 | Televison & Video
Trying to install an in dash stereo can't figure out the speakers
depends on what wires you need the back of the raidio will have white grey green purple white is front left grey is fr green is back left and purple is back right if your lookin for truck colors get a manual or check to make sure there are no hots or grounds with a meter and twist one of the speakers ground up and with the hot touch each wire til u get sound idenitfiy the speaker wire to corect chanel
Feb 18, 2009 | 1995 Nissan Quest
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
LCD show purple or violet cast on white areas when using auto mode
Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
Dec 31, 2007 | Nikon D40x Digital Camera
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
