Tip
Transfer photos from Camera to PC
<span><span><i><b>Hello and welcome to FixYa!</b></i><br />
<br />To transfer your photos from your</span><span> Digital Camera</span><span><span> to PC, Follow the given steps:</span><br />
<span style="font-weight: bold;">1.</span>First connect your digital camera to your computer.<br />You can do this in two different ways:<br />
<br /></span></span>
<ul>
<li><span><span>
<b>Use a USB cable:</b>Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.</span></span></li></ul>
<ul>
<li><span><span>
<b>Through memory card:</b>A memory card reader is a piece of hardware
that plugs right into your computer. You remove the memory card from
your camera and insert it into your memory card reader, similar to the
way you might transfer a file between two computers using a floppy disk.</span></span></li></ul><span><span>
Now connect USB cabe or Memory card Reader to the port of the computer<br />
<span style="font-weight: bold;">2</span>.Once you've connected your camera to your computer or inserted your
memory card into your memory card reader, your computer will detect the
connection and ask you what you want to do with your pictures. If you
connected your camera with a USB cable, click <b>Microsoft Scanner and Camera Wizard</b>, and then click <b>OK<br /><br /><img src="angel_bird_1.gif" /><br /><br /></b></span></span><span><span>If you are using a memory card reader, click <b>Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard</b>, and then click <b>OK</b>.<br /><br /><img src="angel_bird_2.gif" /><br /><br /></span></span><span><span><span style="font-weight: bold;">3</span>.When the Scanner and Camera Wizard appears, click <b>Next</b>.<br />
<span style="font-weight: bold;">4.</span>All of the pictures on your camera (or in your camera's memory card)
are now displayed on the Choose Pictures to Copy page. By default,
Windows XP selects all of the pictures for downloading. If there are
pictures you do not want to download, just clear the check box next to
those pictures. At this stage, you can also rotate pictures that you
took while holding your camera vertically. To rotate a picture, click
it, and then click either the <b>Rotate clockwise </b>or <b>Rotate counterclockwise </b>button
on the lower-left side of the page. When you have reviewed the pictures
for downloading and rotated your vertical pictures, click <b>Next</b>.</span></span><br /><img src="angel_bird_3.gif" /><br /><br /><span><span><span style="font-weight: bold;">5.</span>On
the Picture Name and Destination page, type a name for the group of
pictures. (This name, plus a number to differentiate each picture, will
be applied to each of the pictures you download; for example, if you
name the group "Vacation," the pictures will be named "Vacation001,"
"Vacation002," and so on.) Click <b>Browse</b>, and select a folder in which to save your pictures.<br />
<span style="font-weight: bold;">6</span>.If you want to erase the images from your camera's memory card to make space for new ones, select the <b>Delete pictures from my device after copying them </b>check box, and then click <b>Next</b>.
The Scanner and Camera Wizard copies the pictures from your camera to
the folder you specified and then removes the pictures from your
camera's memory card.<br /><br /><img src="angel_bird_4.gif" /><br /><br /><br /></span></span><span><span><span style="font-weight: bold;">7.</span>On
the Other Options page, you can choose to publish your pictures to a
Web site or order prints. If you have finished working with your
pictures, click <b>Nothing</b>, and then click <b>Next</b>.<br />
<span style="font-weight: bold;">8.</span>On the final page of the wizard, click <b>Finish</b>. Windows XP opens
a Windows Explorer window showing the pictures you downloaded from your
camera. Your camera's memory card is now clean and ready to store new
pictures. If you connected your camera to your computer using a USB
cable, disconnect your camera. If you used a memory card reader, return
the memory card to the camera.<br />
Your photos are now stored on your PC, ready for whatever you want
to do with them, and <span style="font-style: italic;">your camera is ready to take more pictures.</span></span></span><br /><br /><span>Thank you for Using FixYa!</span><br /><span><span><br /></span></span>
on Apr 28, 2011 | Cameras
