Question about Logitech Harmony 880 LCD Remote Control
2 remotes....same problem
On my second remote since last May. The remotes work great for 5 months....then they stop keeping the correct day/time (resets to a random day/time) and start sending out double commands. The problem is resolved when I sync the remote. It will work problem free (keeps day/time for a few days and correct commands) for a few days and then "glitch" out at random. Any ideas?
    Novelist:
  • 101 Answers
Try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Posted on Jan 21, 2010
What is my tv code for programming my dish network remote.
Hi!
Welcome to FixYa!
You can use these codes to program the Dish remote control to your Sanyo DS32920:
542, 589, 590, 591, 592,609
You may also try Power Scan Instructions. Please follow the steps bellow.
1. While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
4. Press POUND (#) on the remote. The TV MODE button will flash three times.
5. Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
Keep me posted.
Thanks.
Lor04
Apr 07, 2011 | Sanyo DS32920 32" TV
My key remote to lock the doors suddenly stopped
hi yes this can be done, here is how
make sure you have all keys ready to reprogram close all windows and doors insert key into drivers door lock within 5 seconds of putting key in door lock turn key to unlock position 3 times this puts the key into programming mode ( door led should be on ) press and hold lock button, within 5 seconds of holding lock button press unlock button 3 times ( keeping lock button pressed at same time) then release lock button that should be it...to make sure correct programming is achieved key led flashes 5 times, and door led flashes 6 time, if you have more than one key do same as above within 15 seconds of doing the first key..
phew..lol, well i hope that will work for you..please vote thanks
May 14, 2010 | 2007 Ford GT
Remote to TV 1 doesn't work - buttons light up, nothing happens
Press the number zero for 10 seconds and wait until the "remote wizard" pops up. Then just follow the instructions on how to program your remote to your receiver box.
Oct 20, 2009 | DISH Network IR Remote Control
I have an RCA rcr3273n and it does not have the code search button, what button do I use to sync it with my TV?
These are the steps for the auto code search function for your remote.
  • Manually turn on the device you want to control.
  • Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
  • Wait until the remote’s indicator comes on and stays on. Then release both keys.
  • Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
  • Did your device turn off?
  • YES: Go to step 5.
  • NO: Press PLAY again. The remote tests the next batch of 10 codes. Keep pressing PLAY every 5 seconds until your device turns off.
  • When your device turns off, press the REVERSE key on the remote and wait at least 2 seconds. The remote tries the last of the previous ten codes.
  • Did your device turn on?
  • YES: Press the STOP key. You’re done!
  • NO: Press REVERSE again. The remote tests the next code in the batch.
  • Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Because there are a couple other methods you can use to search for codes I included a link to the manual for your remote.
Hope this helps.
http://audiovox2.info/docs/rca_acc/man/RCR3273N_DOC_OM.PDF
Oct 17, 2009 | Televison & Video
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
RCA remote help
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON!!! MY REMOTE WAS THE RCA RCR312W
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Jul 01, 2008 | RCA RCR311B Remote Control
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
Logitech Harmony 880 LCD Remote Control Logo
153 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
