Question about Emerson MW8777W Microwave Oven
Emerson MW 8700W
It quit working when I went to start it. I checked the plug, and it is ok. Is there an internal fuse? Can I get to it easily?
Thanks, Bob
  • Emerson Master
  • 9,098 Answers
The fuse is usually located on the floor of the oven chassis behind the control panel, between the door switches, or near the back where the cord comes into the case.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
Microwave oster
could possibly a blown internal fuse .
Jan 23, 2018 | Oster OGH6901 0.9 Cubic Feet Digital...
Where is the fuse in under-counter miccrowave?
remove the vent grill at the top, may have to slide to left after screws are removed. then you will see a screw holding the control panel, remove. then slide the panel up slightly and the panel should come off. behind the panel you fine a 20 amp 250 vac glass type fuse. remove and replace. if your MW works cool,,,,, if it does not you may need to call for service.
Jan 23, 2012 | Amana Microwave Ovens
No power
Can be seceral things but let me run by the simple ones first.
The MW does not have enough airflow that eill causer the sensor to switch it off. Briing it away from the wall a bit for air flow
The moisture from the defrost caused the sensor to cut in and switch it off. Unplug the MW and leave for a few hours ( tea will be delayed :0)
The Internal fuse blew. The outer cover has to be removed to replace the fuse ( unlug it first)
The fuse may be of the heavy duty ceramic type Do not substitute it)
The throw out to the MW plug went off in h/hold power box. reset it. Test point with another item.
Now those are the simple things you should check. first
The main one is the failure of the magnatron, but you would have lights and turntable activity, so... so far so good.
Please rate our help to keep the FREE service online++++Thank you for using FIXYA
Sep 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not coming on when plugged in
The first step is to check the fuse in the mains plug. If this is ok, one will have to remove the microwave cover (un-plugged) and check the internal fuse.
If this is ok, it's an electronic fault and likely to be expensive to repair.
If the internal fuse has failed, it's usually for a reason.
Follow the above and reply.
regards
Apr 26, 2009 | Emerson Microwave Ovens
Mw8115ssw no power
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson Microwave Model # MWG9111SL keeps blowing fuses..
You have a shorted high voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Nov 24, 2008 | Emerson Black Microwave Oven
No Power
Hi there!
The cheapest way is to break the stud out with a small, strong, flat screwdriver. The give way quite easily. Then a normal multispline should do the job. Check for loose wires and loose solder connections on the display panel. You may even have a fuse that's hanging by a thread, hence the intermitency. Regards and good luck. JUS004
Mar 31, 2008 | Emerson Black Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8777W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
