The copy comes out very dark. The print is dark with a white background just around the print only.This is a Canon PC-6re copy machine
  • 82 Answers
WOW I haven't seen one of those in years and years but a good dependable machine .the machine sounds like it is very dirty inside. the optics(lens and mirrors under the glass) and the corona wires are very dirty.
it really should be cleaned by a qualified copier technician, but if your mechanically inclined i may be able to walk you through it.
you may be able to get cleaner copies by pressing the "A" button and sliding or press ing the buttons to lighten the copy, that should temporarily fix it
Thank You,
Mikey
Posted on Apr 05, 2008
Canon PC-6re started printing all grey copies and then the light went out.
my printer dcp-j125 hai jo kaafi time se ink absorver full on the see uska solution give
Nov 17, 2013 | Office Equipment & Supplies
MY CANON PC 6RE COPY MACHINE PRINTING ALL BLACK PAGES. IS THIS A FIXABLE PROBLEM?
Check the terminals that touch the drum unit. One of them is making a poor contact.
Jul 25, 2011 | Office Equipment & Supplies
Cannon 6 RE PC gives black copies
does the lamp under the platen glass turns on when copying? if not you might need a new exposure lamp...but if you get an image but its very dark, if you are mechanically inclined you can clean the mirrors and lens and the bottom of the platen glass because after many years of use dust will make the optics dirty and cause the copies to be very dark. hope this helps.
Dec 31, 2009 | Canon Office Equipment & Supplies
Dark copies, copier pc-6re needs cleaning, no manual
Clean the optical parts (mirrors,lens and lamps),charge corona wire and the transfer /separator corona wires and unir and make a copy.If not good tell me.
Nov 30, 2009 | Canon Office Equipment & Supplies
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Canon PC-6re copies are all black
1-the scanning lamp is not coming on
2-seperation is not working properly
3-the HVT for the seperation is not working
Oct 07, 2008 | Canon IMAGERUNNER 6570 Copier
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Canon PC-6RE Exposure Issue
why certainly, you can either call me and I will walk you through it. the canon pc 6 is a great machine except if you have to change fuser lamp or upper roller. otherwise very reliable call me at 813-323-1410.
Thank You,
Mikey
Apr 03, 2008 | Office Equipment & Supplies
136 people viewed this question
jasbo
jasbo
