Question about HP PSC 2210 All-In-One InkJet Printer
The printer can't feed paper
Hi, my all in one printer can't feed paper. How do i solve it?
  • fhed Apr 04, 2008
    Thank you, we have tried to have it repaired (though not in HP) but was unsuccessful so far. I will have it brought to an HP service center.
    :-) fhed
    Genius:
  • 2,785 Answers
Dear fhed
your printer is having problem in paper feeder roller.If you can your printer then you check the roller.It will be better if you send the printer for servicing
Posted on Apr 04, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 04, 2008
    dear fhed
    please ignore the previous post as it is missing words. I am posting again
    your printer is having problem in paper feeder roller. If you can open your printer then you can check the roller for damge or any obstruction.
    If you are not familiar with opening printers my suggestion to you will be that you send your printer for servicing.
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Paperstuckup
Turn the printer off and on.This automatically pushes out the stuck paper.Solved?
Open cover to gain access to the paper path and pull it out firmly but with care.
Check through the paper paths for any other obstructions.
Avoid filling the paper feed tray to capacity.Solved?
Disconnect from power and connect again.Turn it on.
Hope it helps.Thanks!
Jan 01, 2012 | Samsung Office Equipment & Supplies
Paper jam
Hi Fred,
Check through the paper paths for any obstructions.
Remove any stuck papers manually.
Solved?
Disconnect the printer from PC,unplug from power and reboot your PC.
Re-connect printer and start your PC.
Try printing now.
Hope this helps.Thanks!
Jan 01, 2012 | Office Equipment & Supplies
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Hi my this model of printer is not pulling the paper..how to solve it?
Hi, Manually you can feed the paper right? top feed or front feed. LQ 300 has a sensor for paper feed, if it cannot feed paper automatically there could be something wrong with the paper feed sensor. Sensor of which is just a switch that once the paper pass, it will trigger the switch. If you can open up your printer, you can check the switch if still working. If you manage to locate the switch take out the switch and have check by ohmmeter tester to check the continuity. It sound technical but you can ask help.
Jun 21, 2011 | Epson LQ 300+ Matrix Printer
Hi, My printer intakes paper,but not giving out after printing.my printer is HPdeskjetF380 and paper feeding sound comes immediately error code shows paper jam . i have cleaned the paper tray , cartridges...
Hi there !
You computer need to hard reset start or maybe the ink cartridge is jammed :
Here is the link on how to solve your problem and just follow this to your printer.
Jan 14, 2011 | HP DeskJet F380 All-In-One Printer
Paper feeds fine from the manual tray but the main tray (the bottom) I continuously get a paper jam. It begins to feed then jams. Anything I can do to fix this?
Dear,
No problem.I can solve your problem.There are printer has two paper feed system 1) manual feed2) on cassate.When you get a paper jam in cassate you clean paper clauth or cassate feed roller clean.Some times is missfed because it can not creat frashor in correct.Clean it then solve you problem.Or some of paper bit here.
Dec 09, 2009 | HP LaserJet 1320n Printer
Error Message Out of paper
Contact hp. They have a small item (roller clelaner) that you insert it into the printer as if it were paper and it seems to clean up your rollers. It takes about 15 minutes and it works. I also had the same problem and this solved the issue.
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
