I have a wireless g broadband router i am connected on the main computer but my wireless computer says connected but i cant go to any web pages
    Sergeant:
  • 349 Answers
Is the problem that "nothing coming from the modem to the router"
if the router has more than one Lan port try the cable from the modem to the router, in the first lan port or the last port.
if its a wireless problem,ensure wireless router function is turned on ,and the adapter is enabled on the pc ,
if you set up a security key in the router ensure that it is put into the other pc wireless setting.(but try setting up without any security keys) when succesfull you can ad the security measures.
sometimes you need to turn on the modem first then turn the router on after a little while to sort the ip address out before trying to connect the other pc, in the first instance.
hope this is of help
please rate my efforts as this is our reward
good luck
Terry
Posted on Apr 04, 2008
6ya staff
SOURCE:
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
Cant get my router to hook up to my wii
Is it wireless ?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Apr 21, 2010 | Linksys Wireless-G Broadband Router
Laptop cant connect to internet
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Cant find security settings for voyager 210 router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 10, 2009 | Computers & Internet
Cant find my web key what should i do?
You will need to check the wireless settings of the router .
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Open the set up page of the router and find out the network key.
Click Here for more info
Nov 28, 2009 | Microsoft Broadband Networking MN-700...
Linksys Wireless-G WRT54GX cant find just the driver
You do not need the drivers for this router to get it worked with your computer. You can simply set it up after you will login to the router page.
You need to connect your computer to the router and than router to your modem, and than you will get an ipaddress with default gateway on your computer from router and once you will click on save settings on the main router page, you will be all set and good to go.
Jul 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Open Questions:
Computers & Internet Logo
43 people viewed this question
Ekse
Marvin
Marvin
