Question about Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
I have had my Mitsubishi WD-52628 52" for about 2 years. The bulb went out so I replaced it. After turning on the TV, the screen is not holding a stedy picture. it looke lke an old scrambled cable channel. It does the same thing with all s-video, composite, and rca inputs. Screen looks fine in pip. I tried a hard reset and nothing has worked so far. Any help is appreciated.
  • jesfknkrys Apr 07, 2008
    Thanks for the advise. I took the board there was no visible swollen capacitors. After putting the TV back together, the status light turned on now I am unable to power on the TV.
  • jesfknkrys Aug 26, 2008
    Changed the capacitors and the TV powers on again, but still has the picture not syncing problem. Do you have any other recommendations?
    Problem Solver:
  • 11 Answers
EVERYONE WITH THE BLINKING GREEN TIMER LIGHT ISSUE NEEDS TO PERFORM A "FACTORY RESET" WITH THE REMOTE. Power up the TV set then immediately enter "MENU 1,2,3" to get you to factory reset!!
Posted on Jun 20, 2012
  • Kato Jun 21, 2012
    Additionally the remote needs to be original or a universal remote that has a working "menu" button, "numbers" buttons and the "up, down, left, right" buttons to access this fix.
  • Kato Jun 21, 2012
    Also for the record I want to give credit to tvtechlady on this site for the answer to the blinking green timer light issue. She was the only one with this advice. Thank you, Thank you, Thank you!
  • Mitsubishi Master
  • 8,617 Answers
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Posted on Apr 04, 2008
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Mitsubishi wd-57831 the tv was in the garage for a year because the bulb went out. I replaced the bulb and now the picture is fuzzy. Could this be a dust accumulation problem?
Possible but not real likely--check first to see if any rear audio/video input works well or not--if all else fails and rear inputs work you can route the signal there with a cable or satellite box that has those outputs on it to one input on the rear of the set.
If not a connection issue (cable fitting etc) it might be a bad tuner and the rear inputs will bypass that.
Dec 17, 2012 | Televison & Video
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Error message: check connections or power-the connections for RGBHV or YPrPb may be invalid. The screen is a two tone blue and is flashing.
DO NOT do anything to your Mitsubishi WD-52525 until you read this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html . There has been a worldwide problem in computers and TVs over the past several years with faulty electrolytic capacitors (from Taiwan) that decay, dry out, swell and die. The power supply is often the first component to go bad, but other systems also degrade over time. As the forum explains , this problem is widespread in these sets causing multiple types of display problems after several years of use. Mitsubishi is aware of the problem and will cover most of the cost of repairing the chassis, even years out of warranty, but apparently ONLY if you get an estimate from a Mitsubishi certified repair station and contact their customer support BEFORE doing any work on the set. I just followed the recommended procedure on that forum and Mitsubishi is covering half the cost of my $700+ repair when my 3+ year-old set recently died and showed only a blue screen. I'm not sure if this is your problem, but it might be.
Apr 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsu WD 52525 confusion
to change the channels on the vga side you need a tuner that has separate component inputs and you would change the channel on that
Jan 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52628 52" Projection HDTV Logo
270 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
