Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
DAEWOO DP42SM You seem to be an expert on this model. I have one that displays everything perfectly. However, the SVGA input has become a bit fuzzy (looks like interference). It gets better/worse depending on how long the unit is running. I know it isn't a refresh rate/resolution issue as I've tried other values and PCs. Interestingly enough, the screen overlays still appear perfect as does the component inputs. Any ideas? thanks, Justin
  • 56 Answers
Sorry I was off for a long time.Same thing I said before will work for you,replace all capacitors its typical capacitor problem.
Belive me nobody is expert in electronic its just expirience and mine with this model is that there is no good capacitor on psu and vps board:):):)
Posted on Sep 17, 2008
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
Jan 05, 2014 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Daewoo DP42SM How Do I check what type of Display panel I have, I have to order a power supply but i need to know if it is a NEC, LG or OEC? Please Help Cjoego
Often looking through the ventilation holes in the back of the plastic housing of the TV you can see screen type but it may take a bit of searching. Most of the time you wont need to remove the plastic housing to see this. I know that a 42" Soniq plasma TV has an LG panel inside by looking through the ventilation holes at the LH rear corner of the plastic housing.
Sometimes you may be able to read a part number or model number by this method of viewing.
Feb 18, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
How can i fix my daewoo plasma have 2 vertical lines on the center of the screen?
Only a servicenter can fix it now. You have a bad screen display. Very common on Plasma's
Dec 28, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
All (4) video inputs are bad
possible change your AV cable...you can't use the same component cable for the normal AV input...component cable (RGB - RED,GREEN AND BLUE),normal AV cable is RED,WHITE,YELLOW.
GOOD LUCK.
Dec 09, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
SCREEN PROBLEM
he same problem with my deawoo plasma
Sep 26, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Fuzzy picture
Hello bcarrington2,
If you are using one of your digital inputs and this is happening, I would suspect the video signal processor, the scan drivers (This is called many things but I prefer this name), I have seen these cause this problem. I would suggest if you do not have electronics experience, that you should take the TV to a qualified repair shop to have it taken care of.
I hope this helps,
Thank you,
Shuttle83
Sep 09, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DP42SM coloring missing blue tint on dvd playback only
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Feb 15, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
295 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
