How to hookup surround sound to my tv
I have a Durabrand HT-400 it works with my dvd player but not my tv. I have a ilo TV it has all kinds of connections in the back.
Please help
swtchks
  • swtchks Apr 04, 2008
    Do I need my remote to make this work ?
    swtchks
  • swtchks Apr 06, 2008
    Is it possible that my aux is blown out.
    Thanks for helping
    swtchks
  • 682 Answers
Connect audio out left and right from your tv to aux in or line in in your durabrand ht-400
Posted on Apr 04, 2008
  • Anonymous Apr 06, 2008
    you need to select if you connect to aux in or line in(if it is possible with direct switches or remote it is the same)
SOURCE:
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
Hookup diagram
easy.connect the dvd trough optical cable to the amplifier home theatre for surround sound and the video where it says DVD input and the sony cassete deck where it says cd in A/V the red cable wwhite and yellow,
Jan 20, 2010 | Onkyo HT-S790 System
Need to know how to make the surround sound work through regular T.V. with durabrand surround HT-3915
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
Jerry G.
Feb 22, 2009 | Durabrand HT-3915 System
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at [email protected] and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
Cant install surround system to TV/DVD/XBOX360
Use audio out on t/v and plug that into input on the surround reciever
Dec 22, 2008 | Durabrand HT-3915 System
Durabrand ht 400
i got everything hook -up stereo works but my tv surround does't i push test button it works but no surround from tv
Jul 18, 2008 | Audio Players & Recorders
Surround sound works with ht-x30 dvd player when playing a dvd but cannot get surround sound with tv only
Is the surround sound integral to the dvd player and not connected to the tv. if it is connected to the tv either by scart or phono leads. do you have to select another input from the surround sound. such as aux or tv
Mar 23, 2008 | Televison & Video
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
577 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
