Question about Sega Dreamcast Console
Won't read disk
The dreamcast says to please wait while disk is being checked and when it doesn't read it and i try again it says please insert the disk when it is already in.
  • Kyzar123 May 16, 2008
    The same thing happens to Sonic Adventure.
  • SonicXXXAmy Jun 01, 2008
    Yeah, I have the same problem, only it's only for one game. My last Dreamcast stopped reading all disks, and when that happened, I gave up on it and threw it away. :/
  • 22 Answers
This has also happened to me
but you can get the disk relayered at game stores and also you can buy disks with small brushes that clean the lens.
make sure youve never touched the lens.
Posted on Jun 13, 2008
  • 23 Answers
Certain Sega Dreamcast Consoles have issues with the laser lens and the motor of the disk reading system. Some of them die after a certain period of use.
Posted on Jun 04, 2008
SOURCE:
Dreamcast cuts out after or during the startup screen, stops displaying audio and video. If a disk is inside, it doesn't shows no signs of even being on aside from the power LED and the fan. The system...
This is probably the most ridiculous thread I've ever read in regards to the most common fault of the Sega Dreamcast. The issue is not with the laser - if it was unable to read the disc, it wouldn't read the disc.
The issue is actually with the pins that connect to the motherboard. They corrode and burn out over time. This can be fixed by cleaning with a high percentage alcohol.
Make sure you have unplugged and turned off the console for a couple of hours beforehand.
And before you open it up, press the on button to check for any remaining power.
Instructions are here http://www.mmmonkey.co.uk/dreamcast-random-reset-and-common-fixes/
Sep 17, 2011 | Sega Dreamcast Console
I go to play a game and it says please insert a cd it scans than says it again,it only says it on one of my games.
Hello there. From what you are describing it does not sound like the issue is with your DreamCast. I would check the disc in question for any fingerprint, dirt or other debris and clean it regardless with water or a lens cleaning solution and wipe dry with a microfiber cloth or other (soft material). Wait for the disc to fully dry before reinserting. The only other thing I can think of but unlikely is laser burning on the disc which can cause some mild warping or marring. I only mention this since the DreamCast system has been obsolete for quite some time the game you are playing is more than likely well used. I hope I was helpful but if you have any more questions please feel free to ask.
Apr 22, 2011 | Sega Dreamcast Console
Dreamcast is not reading disk says please put in disk
There can be 1 or 3 problems with this
1 The laser lens needs to be replaced
2 The motor that spins the disc needs replacing
3 The motor that drives the laser carriage needs replacing.
90% of the time its the laser lens
Jan 25, 2010 | Sega Dreamcast Console
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
Dreamcast turned off when there's a disk in it
madarchod band kar de ......from ayush yadav lps lko
Apr 08, 2008 | Sega Dreamcast Console
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Sega Dreamcast Disk-reading piece
cripes I think you may have mixed your screws up?
1 it sounds like you are using a self tapping screw (it has a greater distance between each layer) rather than the tight screws which are for fitting the circuits together.
2 I believe there are three screw holes for the disc reading part of the dreamcast and you really only need two to keep the disc player in place, so also try another hole.
3 and one last thing to check you haven't put a screw underneath the board already?
Nov 06, 2007 | Sega Dreamcast Console
My DC will read my games but it wont play them!!!
ok guys i have 4 dreamcasts the problem is people beat the crap out of em. try holding the lid partially closed with a weight on top it should read the disk and play good. the sensor that tells it there is a disk in there is probaly a little screwed up. Also get a clean cue tip and some 91% rubbing alcohol and gently clean the lens on the laser and it sould work like new. so get to the browser with the lid open all the way put a disk in and slowly close the lid at about 80 percent closed it should say reading disk put a weight on the lid to keep it where it is and try the game if it works your good. permenent solution. remove modem and the 4 screws at the bottom of the dreamcast without a disk in there pull the top off. now look at the part of the lid that hits the little black flapper (it's on the top right of the main board) now tape or glue a small amount of anthing to the part of the lid that hits the switch about 4 mm thick of paper taped to it will push the switch further in and it should recognize disks better now and all will be well in the world e-mail me for pix if you want [email protected]
Jun 09, 2007 | Sega Dreamcast Console
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Sega Dreamcast Console Logo
464 people viewed this question
Top Sega Video Game Consoles & Games Experts
Karl Roche
Karl Roche
tamaracrum
Level 1 Expert
Ekse
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
