Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover F7431-900 steam vac brushes wont work
The vacuum works fine. hand tool brushes work fine too. its just the bottom brushes wont spin. how to remove the hood to check inside?
  • Nitewing Apr 30, 2008
    How do you remove the cover on a Hoover Spinscrub?
  • Anonymous Jul 21, 2008
    I have the same problem with steam vac hoover. everything works fine except the brushes wont turn. My machine was fairly new at the time I noticed. What gives?
The brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
Posted on Jul 29, 2008
  • 3 Answers
Http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Heres the exploded view. Probably need part #23
Posted on Jul 01, 2008
SOURCE:
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Hoover terrain steam cleaner, brushes wont spin
The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
439 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
