Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Bottom 2/3 of photo is black
Suddenly tonight the bottom 2/3 of my shots are coming out black. The shutter is releasing. I took the lens off to check. I changed the battery, lens and card, but nothing helps. The camera is 4 yrs old. Any ideas? Thx!
  • 1 more comment
  • SCJorgy Apr 14, 2008
    I also have the same problem...it seems many people out there on the
    internet do. Anyone know what the problem is or how to fix it?
    Shannon
  • wellafan May 02, 2008
    my camera dropped from a chair but it is inside a shock proof bag. later, when i tried to shoot a picture, 3/4 of the picture is all black. checked the 18-55mm lens and the sensors inside but nothing was broken. pls help!
  • Anonymous Jun 10, 2008
    I have the same problem with the mirror.
    Also, I can see a loose screw in the picture if I take it upside down!!
    Novelist:
  • 153 Answers
As guest says, most likely the auto focus mirror...
http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
if you do decide to attempt the sub mirror repair take great care, that big black cylinder is the flash capacitor and its charged to 350v and will bite hard....
best of luck
Posted on Jun 04, 2008
It sounds like your autofocusing mirror is loose and obstructing the shutter.
Posted on Apr 26, 2008
SOURCE:
Every shot is coming out black
Have to checked to see if your exposure compensation settings are set to way underexpose your images? This will override all settings and darken your photos. Does it do it when you have the camera set on auto and/or manual? If not, and the images don't come out in the camera and on a computer then there may be an issue with the auto aperture in the lens. Try a different lens and see if it persists. There could also be a shutter issues but you'd usually get an error message with both these problems.
Jan 03, 2013 | Canon EOS-10D Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
While taking photos today during a football game, after about 20 shots, my camera continued what seemed to be regular picture taking, but when I checked the shots in playback mode, the screen is blank! Any...
the shutter most be out or the mirror most be out of timing. if the shutter is bad then it will cost around 180 but try this first turn on the camera take the lens off and hold the mirror with your finger up and press the release switch it should click twice then put on the lens and shoot hopefully it will fix it if it didn't its the shutter
Sep 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Nikon FG 35mm
If its black when you look thru the viewfinder its likely because the mirror is stuck in the up position. It will often do that if the batteries are exhausted. Try replacing the batteries.
The mirror might release back down if you turn the shutter speed dial to M90. This is a manual release of 1/90 second for when you need the shot but don't have any power.
When you look in the lens opening and adjust the aperture dial, you are seeing the aperture open and close. Not the shutter. You need to open the back of the camera (without film) and take a photo to see the shutter curtains open and close.
You should have a read thru the manual to become familiar with the camera and its operation:
http://www.cameramanuals.org/nikon_pdf/nikon_fg.pdf
Jan 03, 2009 | Nikon FG 35mm SLR Camera
Screen is black for photo taking
Not really a solution, but I think you have the same problem I do. I believe that the shutter is sticking. Mine will work for one shot every 3 or 5 power cycles (turn it off and on again)
Oct 16, 2008 | Olympus FE-210 Digital Camera
Error Code
No, it's not an error. What this display indicates, is the availability of the total number of photos you want to take. If the display says, "r06", then you are in JPEG Mode. If it says "r03", then you are either 1) in RAW Mode, or 2) have your Noise Reduction on (see FAQ #2). As you take a few photos in succession, you will notice the indicator drops by how many photos you took.
Mar 01, 2008 | Nikon D100 Digital Camera
Canon digital rebel 300D silver body
Sometimes if you take photos against harsh light, it results in too much Contrast and makes the photos look in B&W. Please explain more details of the problem you are facing.
Dec 27, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Camera seems to operate, won't record photos
there are two possible causes for the problem. 1). a bad CCD or 2) shutter not working. in both the cases you have to contact pro. repairer to fix the problem.
Sep 11, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
85 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
