Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Blinking green light
Yesterday my external hardrive was working perfectly fine...now i plugged it back up and it has a steady blinking light and the computer will not recognize it . Can some please help
  • 2 more comments
  • mikefrench Apr 10, 2008
    same issue, blinking green light. no noise. no whirring. nothing. what do I do?
  • jschmi01 Jun 11, 2008
    Same exact problem. I've tried new power cords, but nothing works. Just rapidly blinking green light.
  • SDL1 Jun 13, 2008
    Maxtor 3199 with more or less same problem. Solid green light. Red light blinks once in a while. When problem first happened I changed the USB cable and the problem went away. But now it doesn't work again. I'd appreciate any advice; it may be under warranty but I'd like to retrieve the data (kids pictures) first.
  • Anonymous Jun 29, 2008
    I find it very interesting that we are all experiencing the same problems at the same time. I to have just plugged my external drive's power supply in and it now blinks green on the light and the drive does not start up. Has anyone found a solution for this problem?
    Problem Solver:
  • 11 Answers
I had a similar problem with my pc( OS=XP SP2) with the same external drive model. I was able to solve it by downloading and installing WindowsXP-KB908673-x86-ENU Hotfix Package from Microsoft Corporation. I hope it works for you.
Nelson
from P.I.
Posted on Jul 11, 2008
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Posted on Jul 07, 2008
SOURCE:
Hardrive connected green light on powercord only blinking and not powering external hardive
Replace the power cable and data cable. If still no help, the drive is dead and needs to be replaced.
Jul 20, 2014 | Western Digital Computers & Internet
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The green "On" light for
Some troubleshooting tips:
  • Right click the printer icon in your icon tray to clear any queued items
  • Go to your printers in the control panel and make sure that the Epson is the default printer
  • Unplug the printer and plug it back in to reset it
  • Push the blinking light/Start/On button on the printer, sometimes printer lights blink after they have received new paper and are waiting for you to "authorize"
  • Open the printer and check for jams
  • Re-insert the printer ink cartridges and close the printer
    Hope this helps!
Mar 15, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My LaCie external hardrive doesn't show on my desktop anymore when I plug it in. This just started today yesterday it was fine, but now the light doesnt even come on
First try to plug it in to a different port on your computer.
If it still doesn't come up, reboot your computer, Still not working? Try connecting it to a different computer.
If the drive still doesn't come up on the other computer most likely the case/ housing will need to be replaced.
Oct 15, 2010 | Office Equipment & Supplies
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
2001 Explorer; anti theft light steady; no power to car
take the positive side of the battery off for about 3 seconds and then put it back on to see if this will reset the security code
Apr 26, 2009 | 1994 Ford Explorer Limited
Camara locked up
Be sure you are using the right kind of batteries in the camera. Check to see if the device requires NiMh, Lithium, etc. It's not just about getting AA size. Alkaline will probably not work properly, and could cause device malfunction.
May 23, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
837 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
