Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
ROLLING TV SCREEN
The screen is rolling, all in black and white, a large black line goes vertical down the screen. It was working fine and happened while I was watching it. It has perfect sound.
After 2 days of problems with it, I finally fixed it by unplugging it and plugging back in! Works like new.
Posted on Apr 04, 2008
Horizontal lines on led/tv with rolling vertically.
This sounds like a panel issue unfortunately, if its under warranty or you purchased an extended warranty great, if not your kind of SOL
Nov 26, 2017 | Vizio Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
IN VGA input from the laptop, too much noise and shaky rolling black & Blue screen.
seems you burned one line actually A output i would say even input but you have to check line a
Apr 17, 2012 | Sony VPL-ES3 Multimedia Projector
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
When viewing images on TV the picture is vertically rolling.
Check the video setting in the set-up menu. It may be set to PAL if you are on the NTSC system, or vice versa. Also check the TV input to ensure your're on the correct channel.
Mar 02, 2008 | Canon PowerShot S2 IS Digital Camera
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Problem with screen on TV
does it roll on normal tv viewing? This is what we call a vertical fault. I don't believe it was because of what happened but U never know. The vertical IC or a faulty cap can also cause this problem. If it rolls on your regular tv programs then it is a fault in the vertical section of the TV
Mar 17, 2007 | Toshiba 27AF43 27" TV
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
423 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
