I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
I got a Princess tent with sleeping bag from Disney foer my daughter thisevening and I too thought the instructions were missing ( foud this site upon searching for it online) until I looked at the hanging label sewn to the pink satin cover for the collapsible posts. look on both sides. You will see the instructions in 5 steps. in case you don't have it,
1, unfold tent and lay bottom flat on a surface,
2. straighten poles and snap together at joints,
3. Insert poles diagonally into sleeves on top of tent.
4. place the end of each pole in pocket on bottom corners of tent,(poles will bend as this is being done.)
5. Hook corners of rain fly into four loops on sides near the top of the tent.
http://www.youtube.com/watch?v=kt5Kw2qxe9Y&feature=related
the above video also explains about snapping the poles. goodluck
hope this helps
So I have 2 daughters myself and they too are crazy about
everything princess themed. I know of a
great youtube video that you may find helpful.
http://www.youtube.com/watch?v=pHwxsiw4p_w
Also, I will send a few links to places that sell these beds
& bedding.
http://www.walmart.com/ip/Disney-Princess-Toddler-Bed/13325927
http://www.nextag.com/princess-toddler-bed/compare-html
http://www.walmart.com/ip/Disney-Princess-4-Piece-Toddler-Bedding-Set/4200986
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
