Question about Franklin Computers & Internet
Key pad is sticking - Franklin Computers & Internet
Xerox memorywriter 6020's space bar sticks
Under each key there is a contact pad, they get old and the foam falls apart. They can be fairly easily replkaced the pads are 1.50 apiece.
Befor you do anything realize that the ribbons are no longer made.
DickyO
Jan 16, 2013 | Office Equipment & Supplies
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
May 09, 2012 | Dell Precision M70 Notebook
When i press select botton my psp hung up
Please check your key pad (select button for sticked ). Replace the key pad if needed
Jan 24, 2011 | Sony PlayStation Portable (PSP) Console
On a 2003 dodge durango, how do the front brake pads come off the bracket? Do you remove the clip to open up a key way?
Stick a flathead screwdriver in between the rotor and pad. Pry against the pad and rotor from the upper side and they'll slide right out.
Sep 26, 2010 | 2003 Dodge Durango
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
Click the Touch Pad tab to adjust touch pad and track stick settings.
May 07, 2010 | Dell Latitude D610 Notebook
It is stuck and no keys will work. It shows small "degree" and "0" only. It will not shut off.
Try taking out the batteries. If that doesn't work it may be that your key pad is sticking. You may need to take apart the calculator and clean the keys so they don't stick. Good luck!
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
Error message F7 on my oven
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the (ERC)= Oven control board
Sep 14, 2009 | Ovens
KEYS ARE STICKING ON MY XEROX MEMORYWRITER 6010
The Xerox keyboards can be rebuilt for about 100.00. Under each key is a foam pad that deterates over the years the must be removed and replaced. If you can get the keyboard to us we will do it for you.
DickyO
Cleveland Business Machines
216-241-0027
Aug 12, 2009 | Office Equipment & Supplies
Frozen key pad
you have a stuck key you need to find which one and you need to blow the key pad off with compressed air to disloge the object that is sticking the key.
Jun 17, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Key pad repair of sony vaio
just stick the b button back into the laptop keyboard while the laptop is off. i havent got any pics to send but just try and do what i just said.
Jul 29, 2008 | Sony VAIO F340 Notebook
Computers & Internet Logo
21 people viewed this question
Top Franklin Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
t d
t d
Level 1 Expert
Are you a Franklin Computer and Internet Expert? Answer questions, earn points and help others
