Question about Whirlpool AWM8143 Front Load Washer
FA fault Tried draining... tooo many suds!! now what do I do? thanks for your help
Have you tried running it empty on the longest cycle at the hottest temperatute with bi-carb instead of soap
Posted on Jul 23, 2008
5d fault what does it mean?
The 5d (or Sd) error code indicate that the control detected a suds lock or overdose of detergent during the drain or spin phases of the cycle. This is usually caused by overuse of detergent. It can also be caused by using regular detergent instead of HE (High Efficiency) detergent. After the excessive suds dissipate, you can normally clear the fault code and then run a drain/spin to finish the load of laundry.
If you detect no excessive suds, this fault code could be caused by a clogged drain system or a failed water level pressure switch.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Hello...my Whilpool Duet washer keeps giving a SUD and F02 error. Now...this just happened a couple months ago and we replaced the Drain Pump Assembly...is it possible that we are once again going to have...
Hello, W/D here.
What you are seeing is the suds (SUD) error code, followed by a long drain fault code (F02).
This does not necessarily indicate that you need to change anything at this time. When the machine senses too much suds, the error code is displayed, when too much suds are actually present, a longer drain time results.
Duets are HE (high efficiency) machines, and require a detergent that produces little suds. If you are using HE detergent, cut back on it until you can run a cycle without getting the SUD/F02 alarms. If you are not using HE detergent (we don't either), you really have to be careful with the amount of detergent used.
Press PAUSE/CANCEL twice to clear the display. Run a cycle without any detergent to flush the machine.
It is advisable to check that the drain hose isn't plugged or have a kink in it.
Make sure that the pump is running. You may need to check the electrical connections at the pump.
You might check the filter on the drain pump for debris or foreign objects, which might cause the drain cycle to be extended.
If limiting the detergent, and nothing was found in checking the other items listed, then the pump may need to be replaced.
Best regards, --W/D--
Please help us by rating our solutions. Thanks.
Feb 21, 2011 | Whirlpool GHW9300 Duet Washer
F02 fault on a hot point washer says motor jammed
I suspected suds build up, so I tried both regular wash cycles (e.g. Normal) and Rinse and Drain cycles multiple times to clear suds in the system, but still received the F02 error. Sometimes the SUD error message came up, but not consistently.
I ran the built-in Diagnostics tests. It made it to C:06 then got stuck.
In both scenarios above, the washing machine continued to try to pump water out, despite the fact that all the water had already been drained. After 8 or so minutes, the F02 error came on. As I understand it, if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
I performed the following with no success:
1. Check Wire Harness connections - OK
2. Check Drain pump. – OK, as water drains at a rapid rate
3. Check Drain pump motor - OK, as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – OK, ran a cable through both hose assemblies (exterior and interior) and not blocked.
5. Check the CCU – appears to function normally.
6. There were no kinks in the hoses, nor was the height of the pump beyond what the manual recommends.
After more diagnostics and troubleshooting, I found that the Pressure Switch was stuck and reported the SUDS state (continuity made between contacts 11 and 14 on the Pressure Switch itself). I ran many Rinse and Normal cycles with no detergent and still got this F02 error. I checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported the correct water level condition (EMPTY and Level 1). In all cases contacts 11 and 14 (SUDS) were continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
I removed the pressure switch and tested it by blowing into the inlet and did hear the switch click, so it seemed to work properly. Given the diagnostics above, I concluded that the pressure switch hose must have been clogged.
Good Luck!!
Thanks
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
FAGOR WASHER FAULT FO2 WHAT IS THIS CAUSE
Good Luck!! Thanks for using FixYa!!
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Suds Suds Suds
The SUDS fault indicator is caused by using too much detergent, or the wrong type of detergent. The Kenmore Elite front loaders were designed to use HE type detergent only. When the washers first came out, manufacturers originally made the claim that you could use regular detergent if you used less of it. The manufacturers later retracted that claim because there were a lot of problems with over-sudsing. If you are not using HE detergent, you need to be. In the mean time run your machine with no load with hot water to clear the drum and drain lines of any soap residue. You may have to do this a couple of times to clear the problem. I hope this helps.
Mar 31, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
145 people viewed this question
Dan Webster
Dan Webster
prem mathew
