Question about Olympus FE-170 Digital Camera
Always Low Battery
Even if the batteries are new it always turns off like having an old and used batteries placed in it
  • 20 Answers
Lens needs replace or repair
Posted on May 18, 2008
How do I get my Sentry Safe S3877 to open when one of the wire is dangling from the battery pack?
Check, you are connecting to the correct spot. That is the place the wire broke off.
It could be you only are using 2 or 3 from the four batteries. Then the voltage is always to low.
Then check you got the right batteries. Never use manganese (Zinc-Carbon) batteries. They don't have enough capacity and can start leaking.
Sep 27, 2014 | Horace Small HS2148 Mens Sentry Plus...
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 03, 2014 | Cameras
Always low battery
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Also check that previous batteries did not leak and damaged terminals
Oct 30, 2013 | Casio Exilim EX-FH20 Digital Camera
The freezer door won't open
Turn off the freezer.
Step 2
Remove the old seal. Most often, this will require removing the screws that hold the seal in place.
Step 3
Clean the seal location so the new seal has a good surface for a seal. If the old seal was held in place by adhesive, it will be necessary to scrape or wash the old adhesive off in order to get a good bond with the new adhesive. Always use a plastic scraper when a scraper is needed so you don't damage the surface you are cleaning.
Step 4
Install the new seal in the same way the previous seal was installed or per the instructions that came with the seal.
Step 5
Place the battery-powered light in the freezer.
Step 6
Check the new seal all the way around. Use the mirror to see some of the harder-to-reach areas.
Step 7
Carefully heat the seal and reshape it where there are gaps. You want to warm the seal to make it soft, not bake or burn it. Try lower heat settings first, turning on high heat only if the low setting does not soften the seal material.
Step 8
Remove the battery-powered light and turn the freezer Turn off the freezer.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Remove the battery-powered light and turn the freezer back on.
Hope this helpout......
Aug 15, 2010 | Maytag MBB2256G Bottom Freezer...
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
Mar 30, 2010 | Magellan Maestro 3210 GPS Receiver
Battery level always shows as low, even when new, charged batteries are placed in the unit.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 20, 2009 | Fuji FinePix S2000hd Digital Camera
Canon a590 always low battery with new battey
Don't use regular alkaline batteries (even though you can...) It's a pain to splurge for the more expensive lithium or photo-specific batteries, but they do last. I take A LOT of pictures with my A590, and can usually get several hundred shots out of a set of good batteries. Try Energizer's web site for a coupon, sometimes they have them available.
Nov 02, 2009 | Canon PowerShot A590 IS Digital Camera
Olympus Camedia C-2020 Zoom - always reads low battery and then "dies"
Safe way - Try using brand new and fully charged NiMh.
Not for novice - Battery contact points may need cleaning. Use contact cleaner with a cotton swab.
Do not try - Spraying contact cleaner or WD-40 in battery compartment.
Last option - Service center.
Mar 08, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Olympus fe 130
Ive had the same problem with my camera and found that it was the quality of the batterys. you have to use good quality high drain batterys for digital cameras.
Nov 02, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
158 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
