Question about GE Advantium SCA2000B Microwave Oven
Advantium Fuse I found your post about the Advantium fuse. I have the same problem. Did you ever find out where the internal fuse is? If so, can you please let me know? Thanks.....Rocco [email protected]
  • xxRoccoxx Apr 28, 2008
    Thanks for the replies. I was able to find it that night and luckily for me it was just the fuse. Probably saved around $100 by not having to call a tech.
    Problem Solver:
  • 4 Answers
I'd like to add a little more description of the process because I tried to pop off the grille over the vent at the front of the oven before realizing that there are two screws on the top of the oven that have to be removed. This is for a below cabinet mounted unit. Once the two screws are removed, the grille comes off. Then there is a small grille held on with one screw just above the display/controls. You do not need to remove the screw holding on the display/controls. Once you take off this grille, the fuse is right there. It is probably a slow-blow 250V/15A fuse (in case you want to get it before you take it all apart).
Posted on Apr 28, 2008
  • cody_shive
    cody_shive Jan 29, 2012
    This was exactly what was wrong with my Advantium/220v model. The fuse was a 250V/20A (20 Amp, rather than 15 as described above). I suggest you make sure you read the side of the fuse before you buy a replacement. Always replace a fuse with an equal to or lower than amperage listed on the fuse with the same voltage rating. If you aren't sure, simply take it to your local hardware store and have them help you choose.
    Getting to the fuse was not hard. The only problem I had was dismounting the unit from the wall to get to the screws holding the grill. If your unit is mounted over a counter, be sure to put a thick cloth over the counter before you remove the bolts in the cabinet above he unit. These units rocker onto a mounting bracket behind them, and then bolt to the cabinet above. To remove, you'll bring the unit down onto its face to do the work. Be careful as you loosen the bolts holding the unit up, as the oven will begin to drop. If you have the installation guide, or download it from GE, it'll help you visualize how to do this. It may be you don't have to bring the unit completely down to expose the screws; but if you do, it's a bit heavy and unwieldy, so have a friend help you.
    One thing to note, however, is why the fuse has blown in the first place. It could simply be the fuse has worn (they do wear with regular use of the oven, fluctuating house current, etc.). It could also signal a problem with the oven. If you find that the fuse is now failing regularly, have the unit serviced (and let them know you've been replacing the fuse).
Remove the housing, it covers the sides and top. Then look above the display near where the 220 cord enters. That is the main fuse. There are 4 others in this oven. Good luck.
Posted on Apr 15, 2008
SOURCE:
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
Advantium 120 model # SCA1001HSS03 has died and working. The circuit breakers is fine. The dedicated electrical line is working fine. There are no lights, no sign of life. The oven was working and at the...
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
Oct 19, 2017 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
GE Advantium mircrowave oven
The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA1000 will not come on
Hi!
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If that doesn't help then there might be a burned wire or a component that can only be found out by opening it up, which is not recommended.
Please rate the solution if you found it helpful.
Thanks
Rylee
Feb 08, 2009 | GE Advantium SCA1000H Convection /...
Microwave oven problem
A fuse blows most often because of an excess of current due to a failed (or failing) component (high voltage cap, transformer, or door interlock switch) or a surge; or due to overheating of the fuse caused by a fuse holder that is too loose.
If replacing the fuse fixes it, then it may have been a fluke surge.
But don't be surprised if it blows again. If so, I would refer you back to my previous solution post here:
http://www.fixya.com/ThreadView.aspx?prdid=481380&thid=1387970
Or feel free to post back with details. Good luck!
Dec 18, 2008 | GE Advantium SCA2000B Microwave Oven
GE Advantium SCA2000B Microwave Oven Logo
1,204 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
