i have old sound card (mup-401) i can't find drive to instal can you help me or you can help how can i know the name of sound card to get the drive thanks
Yamaha RX-V995. I have been having a problem with the remote not adjusting the volume. THe read...
(More)
Yamaha RX-V995. I have been having a problem with the remote not adjusting the volume. THe read out says it adjusting but the volume knob does not move. In the past I would just get up and move the knob a little and it would work again, but now it does'nt work at all. Any help would be much appreciated. Thanks
Powered my yamaha up today and it came on but there is no display. Any ideas to what happened. I...
(More)
Powered my yamaha up today and it came on but there is no display. Any ideas to what happened. I hate to get rid of something that otherwise works.
I have the same problem as others - a 9 year old RX-V995 receiver that would not stay on, and now...
(More)
I have the same problem as others - a 9 year old RX-V995 receiver that would not stay on, and now will not turn on at all. The problem started about a year ago, and my fix then was to leave the unit powered up all the time. If I turned the unit on and off, there were times where it would not turn on. Over the weekend the unit shut off and I could not power it back on. I could hear the main relay drop out in a second. I found that if I pushed on the relay a certain way the unit would power up. That suggested a bad solder joint on the relay. I re-worked the 4 solder joints, but no fix - the unit would not start unless I pressed on the relay again. I now suspect a bad relay (DEC DG1U-12V) - do you agree? If not what else could it be? Where can I get a new relay - and where can I get the Yamaha part number?
