Question about HP Compaq Computer Speakers
Speakers not working
I have a hp compaq computer(desktop) with the speakers inside the moniter and there is no sound. I checked volume and everthing. I troubleshooted the sound and still nothing.
  • babybootoya2 Feb 27, 2009
    when i tried to hook up my speakers it didn't work
    Problem Solver:
  • 14 Answers
Your problem is prevalent anywhere , whosever around the world,,, you had tried everything but nothing happened? Well , the porblem is internal....if you are a hobbyist, you may open your monitor and try checking the circuits where the speaker is being located, check for loose solder. busted wiring , or the speaker itself, maybe one of the wires is cut or dislocated. Word of wisdom,,, bring your monitor at nearby electronic shops if you wish spend a little of your savings. This way you may out of electric shocks if you do it after all. Leave it to the experts....good luck
Posted on Apr 05, 2008
No sound compaq
Check the Audio and Sound Properties. Make sure the volume is turned up and not on mute. Click Start/Control Panel and look for Audio or Sound to check the volume and make sure it's not on mute.
You can also click on the megaphone at the bottom right near the time to check them.
maybe the Audio Driver needs to be reinstalled.
Get onlineand got to www.google.com In the google search box type: "CompaqSupport" or "HP Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.Make sure you have the speakers plugged into the light green port on the back of the computer. And make sure the speakers are turned on and the volume is up.
May 06, 2012 | HP Compaq Presario SR5450F Desktop PC
Installed lynex on my compaq presario sr2010nx and i cant get the sound to work
Make sure the audio drivers are in the device manager. Make sure the volume is turned up and not muted. Look at the Audio/Sound properties in the Control Panel and make sure they are not muted and the volume is up. Make sure you have the speakers plugged into the light green port on the computer and that the speakers are on and the volume is turned up.
Apr 11, 2012 | HP Compaq Presario SR2010NX PC Desktop
How do i get sound to come out of my WF 1907 moniter?
Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and adjust the volume up.
If the issue is not resolved please check the link
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01289551&product=3351970
Aug 06, 2010 | HP Compaq WF1907 Monitor
Recently was not able to hear sound on my computer. Have checked all the basics
My 2cents.
1. Check volume control (Mute, device selection etc)
2. Restart the computer.
3. Try using another speaker.
4. Check the device condition at device manager.
5. Try re-installing the driver, shouldn't hurt trying.
6. Check the cables in your desktop. You should be able to find a guide on the connections of your desktop.
7. Replace sound card if all doesn't work.
Dec 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
Low volume with volume cranked up
Are the speakers battery-powered (with dead batteries?) or AC-powered (but not plugged-in) ?
Do the speakers work correctly when connected to some other desktop or laptop or iPod ?
Oct 09, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Jun 14, 2009 | HP w2207 Monitor
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
Compaq wf 1907 monitor speakers--no sound
make sure they have not came unplugged from the computer also on many keyboards there is a mute button, make sure it has not accidentally got pressed
Jun 06, 2008 | Compaq Presario 5000 PC Desktop
Computer speakers
Are you sure your in the right slot with the speaker wire at the back of your PC it is the green imput. Make sure that the speakers are pluged in if there is a plug for them.
Sorry for sounding a bit basic I'm sure you have already checked these but sometimes people forget.
The volume may be turned off on the status bar at the bottom left of you destop. This is a small speaker double click it and check that the volume is not turned off.
there is no drivers ar anything for the actual speakers unless there is a problem with the sound card in your Dell.
Will you just check that all the wiring is correct and I will guide you through the trouble shooting to see is there anything wrong in the drivers if everthing is ok wiring wise.
Sean
Dec 11, 2007 | HP JBL Platinum Computer Speakers
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
HP Compaq Computer Speakers Logo
129 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
