I can not find word processor on my lap top - Computers & Internet
  • 346 Answers
Start, run, in open box type: wordpad
There is your standard word processor.
What other applications are you trying to find?
Posted on Apr 03, 2008
6ya staff
SOURCE:
The lap top power supply goes off automatically while working sessions
It seems the game giving lots of pressure to your problem and there might be some dirt which is blocking your processor to cool down, So first I'll suggest you to Clean the Processor FAN dust properly and apply heat sink paste on top of the fan.
Aug 04, 2012 | Acer Computers & Internet
My lap top has 800 mhz part number 8f021 processor installed. What Intel part number does this cross to?
8F021 maps to the following Intel part:
http://ark.intel.com/Product.aspx?id=27197
It is an 800Mhz Celeron 100MHz FSB 8x multiplier
Hope this helps. Please rate my answer.
Many thanks,
Chris
Mar 02, 2011 | Intel Celeron, 800 MHz (SL584)
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
Battery maximum usertime&excessive heat generated while using. LENOVO G560 model Under warranty
Most newer lap top computers generate a lot of heat. The designers of the machine walk a narrow line between efficiency and customer satisfaction. The heat comes from the processor and the power supply of the screen. Designers incorporate a standard called heat pipe design into cooling the CPU along with a small fan sometimes. The heat pipe design is a static (no electricity used) means of wicking away the heat from the processor. When the temperature goes higher than the heat pipe can act, a small fan cuts in to reduce the temperature, but at a cost of using electricity from your batteries. The heat of the lap tops have caused people to seek medical help for excessive reddened legs, thus generating a medical syndrome called "Lap top Syndrome"
The batteries are LI-ion (Lithium Ion) construction and have to be re-charged with extreme care as excessive heat generated by charging can case the lithium to burn and cause a fire. Battery designers have placed a small smart chip in the battery pack to monitor the voltage levels and this chip will shut the battery down if too much heat is detected. Since the batteries are of Li-ion design, they start
Dec 29, 2010 | Lenovo G560 06793JU Notebook
Every time i open my lap top screen to a certain degree it turns red. i have to keep the lap top almost closed to get the correct color right
This is unfortunate, as that points at a display problem which in my experience with these laptops comes with very little chance of repair.
In my opinion it is caused by overheating of graphics processor due to the portege's relative small build. The fix would require dissasembly of entire laptop and re-soldering of graphics processor. This takes a technician using a microscope equipped station, and is not cheaper than some new laptop models available today. The non-expensive fix but risky, would be to disassemble board and attempt to re-flow graphics processor connections by heating with heat gun. When I attempted this I lost entire display. My recomendation is to use external monitor if possible, which may prove futile since issue with graphics will likely be visible on that too. good luck
The procedure involves
Jun 16, 2010 | Toshiba Portege S100-S1133 Notebook
No driver for my msi wind u100
u can serch it in internet by writing xp or vista supported msi u100 laptop or note book softwere. i get 15 45 insprine dell lap top softwere for xp becasu i wanted to remove vista. www stock.com help u.
Oct 09, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Video is choppy when transferring flipvideo
I have the exact same problem ... I have a Compaq ... Vista Home Basic, plenty of RAM 1.8GHz ... FLIP told me the exact same thing ... it's exTREMEly frustrating.
Jul 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Lap top wont come up
then u shud contact your vendor and for more contact http://www.techbuddies.org
Jun 19, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Advent lap top 5431isn't loading properly
go into your control panel and tell me the processor speed
Apr 24, 2009 | Computers & Internet
My lap i making more sound
you're right the sound is coming from around where the CPU is but thats not making the sound,, more than likely its your fan (located on top of the processor)
Oct 05, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
124 people viewed this question
Ekse
Marvin
Marvin
