Question about Pitco Frialator SG14 Deep Fryer
Not turning on
I have the pilot light on but when I try to turn the temperture dial to set the temperture I can't turn on the fryer
    Champion:
  • 254 Answers
Sounds like you have a bad t-stat. You could take a reading through it when you turn the temp up to see if it is operating.
Posted on Jul 17, 2008
Commercial fryer cecilware
The valve could be defective.
Sep 14, 2016 | Cecilware FMS-40 Deep Fryer
Why won't the pilot valve turn on my pitco 35C+ frialtor?
You turn the valve knob to "Pilot", push it in, and light it (use a long butane lighter-it's easiest) and keep the button pushed in for 20 seconds-1 minute. If the pilot stays lit, turn the dial to "On".
Apr 21, 2014 | Pitco Frialator Kitchen Appliances -...
Cannot turn the on switch
Hi there!
Try pushing the knob lightly before turning to "on" or "off" position.
Regards.
Jun 28, 2012 | Garland C836-1-35F LP - 35-lb Fryer w/...
Pilot lights but will not light burners when range selector dial is turned on
Hi there.
Check and clean the thermopile, it must be free of soot or any form of dirt so that it can properly sense heat from the pilot flame and generate millivolt to open main valve to fire up main burners.
Regards.
Sep 22, 2011 | Pitco Frialator 35CS Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
Pilot goes out when you turn up thermstat
The thermocouple, the part that is heated from pilot light and produce small electricity and is connected to the gas valve, is a small copper pipe wire, need to be replace since it can not enough electricity so to keep the electromagent on valve on when you try to turn up and the gas coming out from the burner is blowing out the pilot light.
So the most posible reason is to replace the thermocouple which is the cheapest part. Their is a very small chance that the gas valve is faulty but this depents how old the fryer is and how much have been work.
May 09, 2010 | Imperial IFS40 Deep Fryer
The pilot light is on but when the dial is turned nothing happens
make sure pilot flame is in full contact with thermopile
Jul 11, 2009 | Imperial IFS40 Deep Fryer
Honeywell propane relay won't start
For the pilot you have to hold the red button down for about a minute or two while it is lit, then turning it to on. If you tried this and it still wont stay lit then you can try replacing the thermocouple. For the relay the best way to tell is take voltage reading to see if the coil is getting voltage across it.relays are usually inexpensive,and easy to install.Just be sure to turn the power off befor touching the wires,and mark them so you know which wire goes to what terminal.
Mar 07, 2009 | Frymaster Dean 2424G Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
